Wowpen joy mouse driver need
My mouse used to work fine until a few months ago. I have 2 of them, they work on a windows XP system but not longer on my Vista system.
SOURCE: Keyboard/Mouse Freezes System Sporadically
I have a targus AMU0901US mini mouse, and it had been working perfectly on my laptop but today when I turned on my computer it just didn't work anymore. A friend of mine told to unplug my computer from the power outlet and let it for a few minutes, then to plug it again and plug my mouse back too, but it didn't work. it doesn't lit or anything.
Posted on Jan 12, 2008
  • 979 Answers
SOURCE: usb mouse drivers
Go to device mgr and verify that the port in question is always on. Look in device mgr after installing mouse in desired USB and verify that windows has detected it. Typically, there is no additional drivers needed for this type of application, but check with the mfr of the mouse to be sure...accordianman
Posted on Feb 02, 2008
  • 406 Answers
SOURCE: Kensington PilotBoard Wireless Desktop Model#64379 - Mouse does not work
THERE WILL BE ONE BUTTON DOWNSIDE OF MOUSE PRESS IT CONTINUOUSLY TILL IT GETS SYNCHRONISES WITH YOUR PC.
TRY CHANING THE BATTERY AS WELL.
REGARDS
RAFIQUE
Posted on Feb 24, 2008
SOURCE: Driver will not work with Window's Vista
http://www.p4c.philips.com/files/s/spc200nc_00/spc200nc_00_dwv_eng.exe
Posted on Jun 20, 2008
bunnydawg
  • 5158 Answers
SOURCE: Reinstalled xp after Vista . USB port not working
i've found drivers for an ed 500 at
http://ca.lgservice.com/index_b2c.jsp
you can try the drivers... but do NOT use the bios driver
Posted on Dec 19, 2008
Using Windows 7 - My USB logitech M-BJ58 mouse keeps disconnecting/reconnecting. It works fine on my old XP system. I've tried different USB ports, but I'll be working fine then heard the USB disconnect...
I am thinking you may have to do a system restore to before you got the update. Did you update the drivers for the mouse for Windows 7? Sometimes the older OS drivers get buggy on Win 7. You can get the drivers for free from Logitech's website. One other thing to check, make sure the USB connector is not worn, sloppy or has a broken wire under the rubber cover. It can happen. You should be able to remove the last Win update then you will know if that is the culprit. Hope that helps.
Aug 06, 2013 | Logitech M-Bj58 OPTICAL WHEEL MOUSE...
I have a new Logitech K520 cordless keybord/mouse combination. I use it for 2 pc's (1 Xp en 1 windows 7) by splitting it with a ATEN switch KVM CS-12. With my old Logitech combination S520 the switch...
Its all in the updated drivers, however the one OS "XP" may not have drivers available any longer. Remember XP is no longer supported and thus no one wants to write code for hardware being used with XP operating systems.
Feb 06, 2018 | Logitech Computers & Internet
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
I have an HP Media Center PC running XP Pro SP3. A few months ago it began freezing up requiring that I pull the power plug to get back into Windows. Then it would just freeze again, usually within a few...
just unplug all external devices except ur keyboard and mouse and restart,if u still have the same problem try with last known good configuration,then also with safemode with networking, if u still have problem first of all ,in safe mode only basic required drivers are loaded,it could be a driver issue open devicemanger to chk that as well
Nov 20, 2009 | Microsoft Windows XP Professional
My wireless optical mouse is no longer working
You replaced the batteries. Okay. Did you install drivers for the mouse from a CD? Are you using Windows XP? Do you notice any change if you use the mouse on a darker surface as opposed to lighter surface? If the computer installed the drivers for you, then you might want to delete them in Device Manager (might be called something like HID-Compliant Mice. Single click on that entry, press the delete key. You might have to reboot your PC after that. From there you might have to unplug, then plug in the mouse again and you should notice the driver reinstalling. Give it a second and all should be good.
*Access the Device Manager by right-clicking on My Computer, select Properties, go to the Hardware tab and select Device Manager.
Mar 20, 2009 | Computers & Internet
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
My kb-28g keyboard!
If you are running windows xp try running the system restore function on it.
Aug 20, 2008 | A4tech Computers & Internet
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
