Question about Saws
How to replace th 34-010 rockwell-international drive belt
Is there any way to remove the hub that the blade is tightened to so the new drive belt can be installed? The space between the hub and the housing is to small to allow the belt to be slipped onto the toothed drive shaft. All of the parts diagrams don't show any snap ring or any other way to remove it. I spins freely on the blade drive shaft, and moves easily back and forth an 1/8" or so. This indicates to me that there is a snap ring or other device holding it onto the shaft. I have completely disassembled the motor/drive assembly and cannot see any way to release the hub.
  • Joe Gaudenti Feb 18, 2012
    This is a motorized miter box, or chop saw as it is know in the industry
  • 10 Answers
SOURCE: Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
SOURCE: Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
rowdy45176
  • 2176 Answers
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
Posted on Mar 14, 2009
  • 272 Answers
SOURCE: Stripped gear on our Waring Pro FS150 Food Slicer
SmallAppliance.com has the part you need. Waring is no help at all. They only sell the replacement blade! Go to this web site: http://www.smallappliance.com/product.asp?pid=5147&cur=USD&cam=waring_parts&sid=18956&mid=34&gid=18971&prdCls=P&PartsPaNu=1&shopBy=Brand
and get the part. Thankfully they carry the motor gear you need. I had nothing but frustration dealing with Waring trying to get this part. Finally a nice Waring tech told me about smallappliance.com. Good Luck!
Posted on Apr 25, 2009
How do I replace the drive belt?
Depending on which model you have, you will have to loosen the belt adjustment by the gear drive mechanism, then slip the belt over the drive pulley. This should allow enough room to get the belt over the blade and off. It might be easier to remove the blade too.
Then install the new belt over blade first then over drive gear box pulley, then tighten adjustment for the belt at the gearbox.
Jun 23, 2015 | Garden
Replace Front Wheel Hub Bearing 2002 Jeep Grand Cherokee 2 wheel drive
Removal
  1. Raise and support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake caliper, caliper anchor, rotor and ABS wheel speed sensor.
  4. Remove the cotter pin, nut retainer and axle hub nut.
  5. Remove the hub/bearing mounting bolts from the back of the steering knuckle. Remove hub/bearing from the steering knuckle and off the axle shaft.
Installation
  1. Install the hub/bearing to the knuckle.
  2. Install the hub/bearing-to-knuckle bolts and tighten to specification.
  3. Install the hub washer and nut. Tighten the hub nut to specification. Install the nut retainer and a new cotter pin.
  4. Install the brake rotor, caliper anchor, caliper and ABS wheel speed sensor.
  5. Install the wheel and tire assembly.
  6. Remove the support and lower the vehicle.
Apr 22, 2012 | 2002 Jeep Grand Cherokee
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to remove fan
Congrats, I have one 1993 GC Limited and its a nice SUV...
5.2L Engines
  1. Disconnect the negative battery cable.
  2. The viscous fan drive and blade assembly is threaded into the water pump hub shaft. Remove the fan drive and blade assembly from the water pump by turning the mounting nut counterclockwise as viewed from the front while securing the water pump pulley. Do not remove or unbolt the fan drive and blade at this time.
Fig. : Fan blade and viscous drive (click for zoom)
The threads on the viscous fan drive are right hand threaded.
  1. Remove the 2 fan shroud-to-upper crossmember nuts.
  2. Remove the fan drive, blade and shroud as an assembly.
WARNING Do not place the viscous fan drive in a horizontal position. If stored horizontally, silicone fluid in the viscous fan drive could drain into its bearing assembly and the assembly would have to be replaced.
CAUTION Do not remove the water pump pulley-to-water pump bolts. The pulley is under spring tension.
  1. Remove the 4 bolts securing the fan blade assembly to the viscous fan drive.
To install:
  1. Install the fan blade on the viscous drive. Install the bolts and tighten them to 17 ft. lbs. (23 Nm).
  2. Position the fan shroud, viscous fan and blade into the engine compartment as an assembly.
  3. Position the fan shroud to the radiator. Insert the lower slots of the shroud into the crossmember. Install the upper attaching nuts.
Ensure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
  1. Install the fan drive and blade assembly to the water pump shaft and tighten the nut.
Ensure there is at least 1 inch (25mm) between the tips of the fan blades and shroud.
  1. Connect the negative battery cable.
Also, its possible that you are interesting in check the Service Manual ZJ-Secc-7-Cooling-System
Hope helps with this (remember comment and rated this).
Aug 03, 2010 | 1995 Jeep Grand Cherokee
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace to old blade with a new one on a rolux magnum laser lawnmower but don't know how the remove it
Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Garden
2006 dodge dakota water pump replacement instructions 3.7L
The water pump can be removed and installed without discharging the air conditioning system (if equipped).
  1. Disconnect battery negative cable.
  2. Drain cooling system. Refer to Draining and Filling found under Cooling System, Service and Repair.
  3. Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse. WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094). SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS. CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
  4. Remove upper radiator hose clamp and hose at radiator.
  5. The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. A Snap-On 36 MM Fan Wrench (number SP346 from Snap-On Cummins Diesel Tool Set number 2017DSP) can be used. Place a bar or screwdriver between water pump pulley bolts to prevent pulley from rotating. Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
  6. 6. If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
  7. Remove fan shroud attaching hardware (two bolts at bottom-two clips at top).
  8. Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
  9. After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
  10. Do not remove water pump pulley bolts at this time.
  11. Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front). When all belt tension has been relaxed, remove accessory drive belt.
  12. 12. Remove four water pump pulley-to-water pump hub bolts and remove pulley from vehicle.
  13. Remove lower radiator hose clamp and remove lower hose at water pump.
  14. Remove heater hose clamp and heater hose from heater hose coolant return tube.
  15. Loosen heater hose coolant return tube mounting bolt and remove tube from water pump. Discard the old tube O-ring.
  16. Remove seven water pump mounting bolts.
  17. Loosen clamp at water pump end of bypass hose. Slip bypass hose from water pump while removing pump from vehicle. Discard old gasket. CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
INSTALLATION
  1. Clean gasket mating surfaces.
  2. Using a new gasket, install water pump to engine as follows: Guide water pump nipple into bypass hose as pump is being installed. Install water pump bolts. Tighten water pump mounting bolts to 40 Nm (30 ft. lbs.) torque.
  3. Position bypass hose clamp to bypass hose.
  4. Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
  5. Install a new O-ring to the heater hose coolant return tube. Coat the new O-ring with antifreeze before installation.
  6. Install coolant return tube and its mounting bolt to engine. Be sure the slot in tube bracket is bottomed to mounting bolt. This will properly position return tube.
  7. Connect radiator lower hose to water pump.
  8. Connect heater hose and hose clamp to coolant return tube.
  9. Install water pump pulley. Tighten bolts to 27 Nm (20 ft. lbs.) torque. Place a bar or screwdriver between water pump pulley bolts to prevent pulley from rotating.
  10. Relax tension from belt tensioner. Install accessory drive belt.
  11. CAUTION: When installing the serpentine accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Illustration above for correct belt routing. The correct belt with correct length must be used.
  12. Position fan shroud and fan blade/viscous fan drive assembly to vehicle as a complete unit.
  13. Install fan shroud.
  14. Install fan blade/viscous fan drive assembly to water pump shaft.
  15. Fill cooling system.
  16. Connect battery negative cable.
  17. Start and warm the engine. Check for leaks.
Feb 28, 2010 | 2006 Dodge Dakota
Timing Chain Cover, Chain, Sprockets, replacement
2.2L VIN 4 To Remove:
  1. Remove or disconnect the following:
    • Drive belt.
    • Drive belt tensioner.
    • Alternator.
    • Power steering pump. Place the pump aside with the lines attached.
  2. Lift the vehicle.
  3. Remove or disconnect the following:
    • Oil pan.
    • Crankshaft pulley and hub.
    • Timing cover bolts.
    • Timing cover. If necessary, tap with a rubber mallet to loosen the cover.
  4. Clean the mating surfaces.
To Install:
  1. Install or connect the following:
    • Timing cover gasket.
    • Timing cover and the bolts. Tighten the bolts to 11 Nm (97 in. lbs.).
    • Crankshaft pulley hub and the crankshaft pulley.
    • Oil pan.
  2. Lower the vehicle.
  3. Install or connect the following:
    • Alternator.
    • Drive belt.
Aug 29, 2009 | 2002 Chevrolet Cavalier Coupe
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Changing the water pump on 2000 Jeep Grand Cherokee V6
WATER PUMP
The water pump is bolted directly to the engine timing chain case/cover.
A gasket is used as a seal between the water pump and timing chain case/cover.
If water pump is replaced because of bearing/shaft damage, or leaking shaft seal, the mechanical cooling fan assembly should also be inspected. Inspect for fatigue cracks, loose blades, or loose rivets that could have resulted from excessive vibration. Replace fan if any of these conditions are found. Also check condition of the thermal viscous fan drive. Refer to Viscous Fan Drive in this group.
The water pump can be removed without discharging the air conditioning system (if equipped)
REMOVAL
Disconnect negative battery cable from battery.
Drain cooling system. Refer to Draining Cooling System in this group.
The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. Using special tool spanner wrench 6958 with adapter pins 8346 and a suitable fan wrench loosen the fan drive Viscous Fan and Fan Drive Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
Remove two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware Do not attempt to remove fan shroud at this time.
Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic belt tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front) Automatic Belt Tensioner - When all belt tension has been relaxed, remove accessory drive belt.
Remove seven water pump mounting bolts and one stud bolt
Remove water pump and gasket. Discard gasket.
INSTALLATION
Using a new gasket, position water pump and install mounting bolts as shown. Water Pump Installation - Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
Relax tension from belt tensioner Automatic Belt Tensioner - Install drive belt
CAUTION: When installing the serpentine accessory drive belt, belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Belt Routing for correct belt routing. Or, refer to the Belt Routing Label located in the engine compartment. The correct belt with correct length must be used.
Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
Install two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware
Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
Fill cooling system. Refer to Refilling the Cooling System in this group.
Connect negative battery cable.
Jan 10, 2009 | 2000 Jeep Grand Cherokee
Saws Logo
192 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
