I bought a 1gb stick formatted it.all ok took it to asda to have photos done.they could not get info out.it now says stick not formated. data is on there as checked on free data recovery download.really annoying perhaps that why it was only £5 please help
  • 68 Answers
Ally,
sounds like the stick is indeed corrupt, if you say the data recovery app finds the data see if you can use it to recover as much of the data as possible.
You should then be able to format the stick again and give it another go.
Make sure you have original copies just in case it fails again though.
Nick
Posted on Oct 26, 2008
Kingston sd 512mb is still write protected even after reformatted. i can't bring back the photos i transferred to my pc.
Card Data Recovery is professional photo recovery software to recover deleted, lost, corrupted or formatted photos, videos, and auido files from various memory cards, such as, SDHC card, SD card, CF card, memory card, memory sticks, USB devices, digital cameras, hard drives, and zip drives.
http://www.card-data-recovery.com
Jul 24, 2011 | Cameras
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Hey I have 1GB Memory Stick and can't send music or photos on memory with program sony ericsson pc suite when i turn on my phone it says Warning!All content on Memory Stick will be lost ...
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory stick (use quick format), and then use above mentioned software to scan again the memory stick and recover your files.
Mar 03, 2011 | Sony Ericsson K800i Cellular Phone
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
When i turn the camera on it says format error and i cant take any pictures
Please take out memory stick from camera and power up camera and check still gives format error?
If no further error then put memory stick back in camera and press Menu >> Format >> OK to format memory stick. That will delete all data on memory stick and refresh it for new photos.
May 17, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Memory card formatting error
Yeah, if you format the memory card, you will lose all data on it. try to scan memory card with updated anti virus software and always use memory card by camera to PC.
Jul 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lost data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jul 17, 2008 | SanDisk 1GB Memory Stick M2 Memory Card
Memory stick
go to a studio and ask them to retrive - they have a software to retrive even deleted pictures
Then look at the capacity of the memory stick and take pictures
Sukesh
May 21, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Computers & Internet Logo
22 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
