Question about Canon Office Equipment & Supplies
How to adjust fo low lightig
Takeing pictures op people in low light without a flash what aettings do ise
5 Suggested Answers
  • 69 Answers
SOURCE: it wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Posted on Sep 21, 2007
SOURCE: red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Posted on Mar 08, 2008
mcomijohns
  • 477 Answers
I have seen this problem on the ex-s880 casio camera a few times sometimes you can go into the setup menu and reset the camera to default and that some times fixes it. it that does not work I have had to replace the flash circuit on the camera because the large compasitor is out and needs tobe replaces most likely this is your problem because of the flashing LED. Hope this helps its a great camera also you might want to check with casio because this should be covered under warrenty. If the camera was not dropped.
Posted on Apr 01, 2008
  • 44 Answers
SOURCE: sx30is flash off position.
The reason the camera has the green light is not to warn that the flash is off. The green light is used to help the camera auto-focus in low light situations. If you disable auto-focus and use manual focus the green light should not flash when taking the picture. Let me know if that helps!
Posted on Jul 10, 2011
Taking indoor pictures with no flash
If you're in one of the PSAM modes then don't pop up the flash.
You can use the Auto-No-Flash mode by turning the mode dial to the position after the green Auto mode (a lighting bolt in a circle with a slash through it).
Oct 07, 2014 | Nikon D90 Digital Camera with 18-105mm...
Sx30is flash off position. I would like to take a picture in low light without a flash. The camera emits a green light as a warning that the flash is off. I would like to not have either the flash or...
Jul 10, 2011 | Canon PowerShot SX30 IS Digital Camera
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Jun 09, 2009 | Logitech 961462-0403 Webcam
Canon Powershot SLR takes fuzzy photos
Guys,
you need additional flash or brighter light to click in low lighting condition. In order to compensate for low light conditions, the shutter goes slow and therefore you get fuzzy pictures.
Another way is to click on movie(video) mode and then atleast you can see them moving around as well as while editing, you could take out some pictures from the video( though on lmuch ower resolution).
Jan 28, 2009 | Canon PowerShot S5 IS Digital Camera
Nikon D60 - can not shoot pictures in low light
Quick solution: enable the "auto ISO" setting in the menus. This will automatically recognize low-light conditions, and adjust the ISO accordingly.
Dec 24, 2008 | Nikon D40x Digital Camera
Blurred images
This is mainly due to the slow shutter speed selected by your CAM. in low light situations the cam chooses a slow shutter speed to expose the image adequately. Any shakes that may have caused during the shutter operation will cause the funny images.
use tripod or other kind of support to your camera while shootiing in low light (indoors) without flash.
Oct 11, 2008 | Olympus Stylus 760 Digital Camera
Flash
What's perfect to you may not be perfect to someone else, That is why this pro grade camera offers so much in the way of adjustments. One doesn't often GET the perfect picture. More often, one must CREATE the perfect picture..
Set the flash at "0" for the most uniform pictures, and try a better lit environment and work in the 4' to 8' range. Generally, your pictures taken outside in good light, with the sun at your back will be the best. The rest, especially flash, often require some manipulation of the environment..I.E. lighting.
A perfect picture requires a perfect subject, perfect pose, perfect foreground lighting, and perfect background lighting.
So, the answer to you question is; there is no perfect setting, which will constantly produce perfect pictures.
Good Luck..
Aug 28, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Red light continually flashes, and won't take picture
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Canon eos 300d - image to dark
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Jan 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
15 people viewed this question
old marine
old marine
