I have connected the tv and my viao by a HDMI cable and the tv only shows not support on the screen.
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
SOURCE: Sony RMV210 Remote Codes for iLo LCT27HA36
Salutations Schaf1,
This happens with some manufactures. Thankfully some codes will work with other TV's. This is the "Code Search" starts. Your remote has a way to try other codes to see if they will work.
If all else fails it appears Sony has a support hot-line available at 1-800-822-2217 that maybe able to help you find the code. Just make sure you cover all the troubleshooting steps you've already done.
Hope you find that code.
Jon
Go Ahead. Use Us.
SOURCE: remote code
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved (remember that at times a bit of
to and fro dialogue may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: 32in ILO LCD Hd TV
There is a capacitor that is out. It is a 470uf 25v. When you open the back and look at the power board there are three group together. It should be right there. You will be able to tell if the capactor top is bubbled replace it. It should be completely flat.
