Question about Garden
The pull starter on my Morrison BC260B S2 won't
  • meilingwong1 Feb 18, 2012
    I've removed the cover entirely, the string itself seems to be working fine but there's a small piece of metal which looks like it was a spring and a small piece of black plastic which appears to have fallen out of somewhere it's supposed to clip into. Can't make out where these two are supposed to go.....any thoughts?
    Thanks!! Unfortunately the spring had already come out. The string itself is fine. Don't suppose anyone has a diagram of the pull starter and where all the bits should go? I've borrowed the weed eater off a friend and am supposed to return it today. Preferably not broken!!
    Problem Solver:
  • 10 Answers
That weedtrimmer's starter unit, one of the stupider designs I've seen.
With everything dismantled including the spring removed.
It is actually very easy to fix it providing it is redesigned. Redesign takes a minute or so and involves cutting a little slot in the side of the black case, big enough to feed the inner end of the starter spring through.
To fix -
1. Remove the starter unit, 6 screws including the metal bracket over the fuel tank.
2. Unscrew the white pulley in the middle of the winder and remove the starter cord from the handle end. It is knotted in a small metal bracket.
3. Cut a small slot in the black outer housing of the starter unit. This must be in line with the lay of the spring when assembled.
4. Wind up the cord on the white pulley and take a little bit of the string out of the slot in the side-wall of the pulley and tape it down.
5. Refit the white pulley.
6. Feed the spring in through the slot, inner end first.
7. Rotate the white pulley until it catches the spring's inner end.
8. Wind in the spring in until the outer end catches on the black case. This is now its stop/holder point (outside the case but looks very neat).
9. Untape the cord and feed it through the hole (narrow nosed pliers needed) all the time keeping tension on the white pulley.
10. Feed the string through the starter handle and knot the string in the wee metal bracket that it was taken off originally. Feed this back into the handle.
11. Remount the starter unit.
Posted on Dec 16, 2012
    Sergeant:
  • 316 Answers
Hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Posted on Feb 18, 2012
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: CRANK STRING WON'T RETRACT BACK
This is an instruction for replacing the starter cord, but your problem involves the same steps to repair.
This is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Remove the old cord and insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
Posted on Jul 11, 2011
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
The weedeater string part below the Gaurd fell off I disconected the shaft and put the blower attachment on and it works fine. Is it the string head that's bad or the inside cable orthe coplete...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Jun 30, 2011 | Garden
The pull string will not retrack, only ran it once, it stalled and tried to go through steps and pul string won't come out.
find the little oil hole on top of the starter bracket. Squirt some "TriFlone" oil in there and tap the center of the starter with a big screwdriver handle. It should pop right back in -watch out for the rope handle-
If it doesn't- leave it parked in the sun- and by morning the temp change will probably release it. (this called "Spring Bound". in case you want to talk to a mechanic about it.
The worse case is the spring broke. That requires the removal of the starter and fitting a new "rattlesnake" back in there. You will understand that term if you try to do it yourself. But everybody started down the mechanic trail somehow.
May 26, 2011 | Garden
I have the Morrison BC 260B S2 Weed Trimmer but I don't have any instrucions for its use. I need to know what the mix of 2-Stroke petrol is and its general operation. This is not mine and the owner doesn't...
I have one of these. The mix is 25 to 1. Before starting use the primer bulb to get fuel through; it says to turn the choke to limit the flow, but I've found mine starts easier with the choke open. To start, flick to on/start position, hold the (safety switch?) flush with the spine, and give it a yank.
Sep 04, 2010 | Homelite Mighty Lite Lawn Trimmer
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
Garden Logo
530 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
