How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats made in to the caseing acourding to the diagram on the side it has an A prong,an,B prong & a,C the A&B says its low &c says its high I hooked red to yellow and black to black do I hook the brown wire to C prong I traced the black,red&brown tre red &brown go to the capacitor When I hook the red to yellow and the black to black & just leave the brown taped off the fan will not work with out helping it
  • Heating & Co... Master
  • 1,108 Answers
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
Posted on Apr 11, 2017
5 Suggested Answers
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 587 Answers
SOURCE: I am replacing the a/c
Motor Wiring
Old Motor
Brown wire is Start
Yellow wire is run or Power
Black wire is High Speed or Common
The other two taps are speed taps, but you have a single speed application
And high speed is what you need ,that’s why there’s not any wires
on Red and Blue if high speed was to much then you would move the
Black wire to one of the other taps RED low speed or Blue Medinm speed
New Motor
White goes to the Yellow wire from the capacitor
Black goes to the Black wire you took off of high speed on old motor
Of course both Brown wires go to the capacitor and Green to ground
If a capacitor doesn’t discharge it doesn’t mean it’s bad
but the capacitors don’t last as long as they used.
Any time you put in a new motor always replace the capacitor
It will save you a lot of time and grief later on.
Posted on Apr 28, 2009
walterkunesk
  • 683 Answers
SOURCE: I HAVE A 3 PRONG
that is a dual capacitor, common goes in the middle, compressor goes to herm, fan goes to fan. let me know.
Posted on Feb 20, 2011
Need 120 volt wiring diagram for model 113.299410 table saw with model 824370 motor
L1 L2 are the common or line,cord color doesn't mater, green is ground. also should be the ones with screws. try powering the motor for just a few second 2-3 at the most, if it snaps right to life you got it, if it starts slow or not at all, immediately shut it off and check the wiring again. pictures help us fixya guy help u better. there is thousands of different motors
Jay
Jun 03, 2017 | Pool & Spa
Radio/amp wiring diagram 2004 hyundai xg350 ?
2004 Hyundai XG350 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
Dec 22, 2016 | Hyundai Cars & Trucks
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I have a 1991 Chrysler new yorker fifth avenue, I'm trying to convert the radio to a Kenwood... I've been searching for a Diagram and none of them have the colors that are on my car...
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 3 1/2?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Right Rear Speaker Negative Wire (-): Brown/Yellow
Oct 03, 2010 | Chrysler Fifth Avenue Cars & Trucks
Replaced fan motor for outdoor ac unit old fan has blue,black,red,and green wires new fan has brown,black,yellow,brown/white and green what goes where
Hi, the 2 - brown wires are for there own run capacitor they should have sold you. One of the browns will have a white stripe. The new cap has only 2- terminals and you put a brown on each side. The black and yellow wires are both hot which 1- will go to 120 volts on the load or out side of the contactor, and the same with yellow, 120 volts. This gives you 220 volts to run the motor. Look on the new motor and you will have a diagram or on a paper that comes in the box. The old motor used the dual cap to run the compressor to. The green is just a ground wire. Screw it to any metal part or screw. You should be able to put the black and yellow hot wires where the old black, red, or blue were as long as they are 120 volts which I am sure they are. Get a cheap tester when you go get the cap for the new motor, and check the old blk, red, and blue terminals to ground and you should have 120 volts on at least 2 of them. Put the new yellow to 1 and black to another, browns to the new cap and your off and running. Keep me posted. I do this everyday. Please be kind when rating me, thank you.
Shastalaker7
A/C, Heating Contractor
Jul 09, 2010 | Heating & Cooling
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
I am trying to wire a travel trailer that is 30 yrs old. I have red, white, black, brown, yellow & green wires. I have a 4 color pig tail off of the suv. how do I get the lights to work
Red is brakes
brown is clearance lights
yellow is right turn
Green is left turn
White SHOULD BE GROUND but may not be
you will need to test and determine if white or black is ground
The four wires coming from your SUV are clearance right, left and ground
Dec 27, 2009 | 2003 Saturn VUE
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
I am replacing the a/c blower motor and capacitor. The old motor has 1 brown wire to the capacitor, 1 yellow wire to the capacitor (the yellow then loops from the capacitor over to the wiring panel), 1...
Motor Wiring
Old Motor
Brown wire is Start
New Motor
Apr 27, 2009 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
