Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
Nikon CoolScan 4000 shutsdown intermittently
Sometimes before I even have a chance to scan the first slide and sometimes in the middle of a scan.
Beni S-P
  • 1006 Answers
SOURCE: driver for Nikon Super Coolscan 4000 ED scanner
Here u have and please if it was helpfully for u rate this solution as solved:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Nikon-Super-Coolscan-4000-ED-110.shtml
Posted on Nov 02, 2007
computafixa
  • 317 Answers
SOURCE: trouble ejecting slide from SF200 nikon coolscan 4000 ed
open the case of the scanner, and check to make sure that the ejection mechanism is not malfunctioning, or jammed someway.  If this is not the problem, try using thinner slides as thicker ones could also cause this.  If all else fails try un plugging the scanner for a few minutes, and try again.
Posted on Jan 10, 2008
mattozan
  • 555 Answers
SOURCE: Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Posted on Jul 09, 2008
SOURCE: yellow color cast to scanned slides
It's been several years since I used my Coolscan IV, so I've updated the drivers, got it talking to the computer, imported the image into Photoshop CS2. The image colors are way off, red is green, another slide has a blue cast, etc. I've turned the scanner off and on several times, reloaded the drivers, played with the settings, etc. What else can I do?
Sharon
Posted on Sep 15, 2009
SOURCE: My Nikon CoolScan 4000 is not working properly.
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Posted on Oct 12, 2010
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Unsharp scans
Sometimes this is caused by scanning a Kodachrome or thick emulsion slide on the "Positive" setting. Set it to Kodachrome and try again.
Sometimes this is caused by dust on the reflector mirror. I know it was a big problem here.
Ifyour scanner is under warranty, you can ship it in to have itcleaned to their service center, or if not, you can give it a shot yourself. Iwould only do this if you are a mechanically inclined person and arewilling to do it RIGHT. Here's a link to instructions:
http://www.pearsonimaging.com/articles/howto/ls5000cleaning.html
Irecommend reading through it at least once before beginning, and makesure you've got the materials you need on hand as well as a cleanworkspace. It worked on our machines. I give them a once over every so often to keep them sharp.
Bryan Clark
DVD Your Memories
Slide Scanning Specialists
Mar 27, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Coolscan 4000ED
Just curious... did you unplug the unit for a period of time, or did you only power it off? I would definitely unplug it for about ten minutes, then plug it back in.
Jan 31, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Overall Blue Tint
You might try resetting the "settings" to factory defaults and then scanning again. I have seen strange tints if the settings get set incorrectly, not sure exactly what is wrong. However, using factory defaults corrects the problem, then change settings one at a time.
Jan 12, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Scanning
Sometimes the software works strangely, with no indication why. Usually it has to do with the many settings which seem to change periodically or when you try to modify settings and something unintended happens. Try resetting the "settings" to factory defaults, see if it makes any difference. If this does not work, try removing the software and re-installing.
Jan 11, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Trouble ejecting slide from SF200 nikon coolscan 4000 ed
Jan 10, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
47 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
