Question about Kenmore Washing Machines
Kenmore washer model # 4121090 will not engage the tub in the spin cycle
The washer timer seems to work fine and the pump works but the tub will not spin. It seems like it is trying to engage but can't.
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
SOURCE: kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Posted on Aug 11, 2008
  • 351 Answers
SOURCE: Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Posted on Jun 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
Posted on Jan 11, 2010
Testimonial: "you were right thank you very much."
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
My washer won't spin
Hello Michael Johnson - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to move forward accurately to properly diagnose and repair the unit.
Jan 04, 2013 | Frigidaire FAFS4272LW Washer
Can't get the water in the tub & it doesn't spin.
TRY THE LITTLE SWITCH THAT ENGAGES WHEN U SHUT THE LID... MY GE WASHER JUST HAD THE SAME PROBLEM ABOUT A MONTH AGO
Mar 14, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a whirlpool washer, model lsr7010pq1, and it won't spin on spin cycle. If I give it a spin by hand it will work. Agitation works fine, and the motor is running fine on spin. Could this be a belt...
when it gets to spin try to open and close the lid and see if it engages spin. if so the timer may not be pausing right before spin to allow the gear to drop and engage the spin cycle. it can also be a clutch or trans issue.you have to sit there through rinse and see if it pauses for a second a few seconds after it starts to drain if not it may be the timer which is common if its not pausing
Jun 06, 2011 | Washing Machines
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 27, 2009 | Maytag Washing Machines
F51 & F72 Codes
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F51 & F72 Codes
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
Washer won't spin.
Sometimes what happens is that oil spills onto clutch, hence causing the washer not to spin. Try opening lid and engage lid switch, start timer to spin and give the tub a push start, if it starts moving you will have to replace clutch and transmission.
Mar 08, 2009 | Whirlpool Washing Machines
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
