Down load manual for hp pavilion dv4-414us
SOURCE: change english to spanish hp laptop
go to control panel, regional languages, languages and keyboards,
Select spanish, put it to the top, save it, your done.
Select the option to put the language bar on the desktop,
then you can switch between languages,
Regards
Richard.
SOURCE: how to downgrade vista to winxp pro at Hp pavilion DV4-1204TU ?
Well, this may make you think twice:
I bought a presario from circuit city last year, and I paid $200 to downgrade to XP. Everything was fine until it crashed last week. IT went completely bizzerk. HP won't provide support, cause I changed it. Circuit City is out of business, not much help there.
Basically, I am completely #$%%@@.
I am now paying to get Vista put back in. :-(
SOURCE: loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
SOURCE: How do I disable double-click on an HP Pavilion dv4 touchpad?
Start > Control Panel > Mouse > Tapping > Uncheck 'Tapping' Box > Click Okay
SOURCE: hp pavilion dv4-1220us overheating then shutsdown
Sounds like you need to take it in for repairs, clean outs and/or replacements.
This product is known for it's heating issue and power consumption. Maybe the fan is starting to wear out and it's affecting the rest of the system. I would suggest checking the warranty on the system, if it is no longer valid, then I would look for a local tech in the newspaper.
