How to connect aztech dsl1000ew(L) to internet
My problems started after my password was reset. I try to log into the modem set up by typing 192.168.1.1 but failed and i cannot get into the aztech login set up. I think my modem still good since i can still see my wireless signal and my old set up name in the net work... but i can't really go in ... to reset it to my new password.... can anybody help
  • jawshua Feb 18, 2012
    gentlemen, .. i have try to login into the modem by typing 192.168.1.1 but still fail to login becuase it cannot load out the modem setting.... am i using the wrong Ip modem./.. but i can still see my modem name in the wireless connection..... my problem is how to get into my modem and change my password according ly
4 Suggested Answers
shaky120
  • 310 Answers
SOURCE: 4200 speedstream modem problem
I guess you probably aint set-up a wireless router before, what you need to do is get it connected up so you revieve local area is connected then, load internet explorer you will recieve a message like page not displayed. where you usually type in www.ebay.com for example type in the number thats on the bottom of the router ie it looks somthing like this 192.168.1.1 for example. a menu will then appear, fill in your broadband username details etc and you should be up and going, if you have problems feel free to email me,, All the best John Auctionscotland@tiscali.co.uk
Posted on Feb 28, 2007
IB4G2008
  • 3587 Answers
SOURCE: Suddenly lost internet connection on 2Wire DSL modem
hmmm...only thing that makes sense here is that your dSL is unhappy...did you check that phone line into the modem? that's what the internet light means when it's out, actually..if its not the line, then it's the modem..
not much else that is off on this.
check your computer warranty here 4 FREE
Posted on Feb 28, 2008
SOURCE: how to connect linksys router with aztech adsl modem
1-Go to ip address of aztech modem 192.168.1.1
2-Default usermname and password is "admin"
3-Go to quickstart-> Turn off firewall (uncheck)
4-Save changes
5-Connect modem to router's wan port
6-Go to router setup , and select connection type as dynamic ip.
7-Save and restart modem
Solution 2
1-Go to modem quickstart
2-Select connection type as bridge, save changes
3-Go to router's setup, select connection type as Ppoe, give ur username and password provided by internet provider
4-Save changes
5-Restart modem and router
Posted on Jun 06, 2008
Aztech HW550 3G problem is Lan port not respon and i get ip 169.254.99.66 - 255.255.0.0 and reset not respon. I cannot login to the router.
An address of 169.X.X.X usually means connectivity issues from your computer to the router.
Try the following:
1. Connecting only the router to the computer, one of the 4 ports together not WAN or Internet. (so remove cable modem at this point).
2. Go to a command shell (cmd in Start->Run).
3. Type in ipconfig /release
4. ipconfig /renew
If you still don't have a proper IP try replacing the Ethernet cable, this can usually be a source of the problem. Also this usually works too, press and hold the Reset button for 10 seconds or so. This should revert the router to the factory defaults, and retry steps above.
Sep 01, 2011 | Aztech HW550-3G 300Mbps 802.11n Mimo...
Whats the security code? and how do i lock it from other people using my linksys.
You can set the password by logging into the router. You can do this via your web browser. You will need to type the router's IP address (the default address is 192.168.0.1) into the browser's address bar. You will then be prompted to enter the current (or default) username and password for the router. After you have successfully logged in, you should be able to navigate to the appropriate section and change the password to one of your own choosing.
Oct 19, 2010 | Linksys Wireless-G WRT54GL Router
How to cennecting Aztech modem DSL600E with Router linksys WRT54G
First!
Do you have a connection in your modem?
if you do, you need to set up the linksys router in DHCP internet set up.
To have access to the linksys you need to go to:
http://192.168.1.1
The password it's admin
and the username in blank (no password)
change the internet setup to DHCP
Make sure you don't have the Same address for 192.168.1.1 or you modem cause if you do you'll need to change the ip address on the linksys router...
Apr 25, 2010 | Linksys Wireless-G WRT54G Router
No internet light..every thing else working..i reset...unplugged and plugged up every thing the right way....im thinkin its somthing to do with at&t
I had the same problem after I tried the reset button. Just log on to the modem address 192.168.0.1 by typing it into the internet address bar. Then log in with your log on and password and the modem will be reconfifured and the light will come on and you wil be connected.
cal
Nov 21, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Trying to reset router it looks right? but can't log on from any computer in house can log on even though it says you are connected
Disconnect the network cable that is connected between the router's WAN port and the cable modem / dsl modem. With router powered on, reset the router by pushing the end of a paper clip into the the small hole in the back marked "RESET" Keep pressure on the switch for 30 seconds, and release.
The router will reboot and be returned to factory settings. You should be able to log into the setup page by pointing your browser to 192.168.0.1 or 192.168.1.1, when prompted for a user name an password, leave the user name blank and in the password box type "admin" (leave out the quotation marks) .
Change settings as instructed by your Internet Service Provider's tech support group.
When done, power everything down. Reconnect the WAN cable to the modem & power up the modem. After 30 seconds, power the router. After 30 seconds, power the PC.
I hope this helps.
Oct 22, 2009 | Linksys Wireless-G WRT54G Router
Lost CD
To get my connection to work, I had to configure my Netopia DSL modem for Bridged Mode and let my router take care of the routing and address assignment. I would also try to get a working connection before configuring security. You can always do that later. You have the order of powering up you equipment correct. Read this link. It works for me.
http://www.dslreports.com/faq/15855
Apr 20, 2009 | Linksys RangePlus WRT100 Wireless Router
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Jan 04, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Hi I Have Problem
Hi Andy,
The WAN port on your Aztech DSL600EW (by default) is configured to be automatically assigned an IP address when connected to a cable modem (Motorola). Connect the WAN port of the Aztech DSL600EW to the Ethernet port of the Motorola, then configure the Aztech for wireless connectivity to your laptop as per the manual instructions.
Apr 18, 2008 | Computers & Internet
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
357 people viewed this question
David Payne
David Payne
