Question about McCulloch Garden
Model # 600086
Muffler
2006 artic cat atv is this model equipped with a spark arrester
most atv models have the spark arrestor built in them if in doubt check your muffler it should say the muffler case should be stamped with lettering saying it is US Forestry Approved.
Oct 10, 2014 | ATVs
We're can I purchase the muffler and everything that goes with it
Any chain saw store should be able to get what you need. Check what kind of saw you have, model number, etc. and then use the internet to find a way to order parts.
Sthil and Husqvarna are two different brands.
Husqvanrna saws are often refereed to as Huskys
Google Search "345 Husky muffler parts":
http://bit.ly/1igUxjF
Google Search "chainsaw parts / Stihl, Husqvarna":
http://bit.ly/1gSCye7
Apr 23, 2014 | Solo 662 667 Chainsaw Muffler W/ Bolts...
Replacing the muffler on the poulan pro 550 model number 961240002 00
there is two ways to mount mufflers on small engines. one with two bolts through the muffler to the block or threaded to it. if you don't see bolt heads then you unscrew the whole muffler.
Aug 06, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
To loud, do they have a better muffler kit
Most likely a different muffler is available for easy bolt-on solution. Best way to check is to find model and type of engine and check with engine distributor in your area or the web. Engine model is usually found on the starter/fan cover or the block. The problem is the limited space within the frame of the generator. Other solution is to contact a small engine service center for modification. There are several sources for quiet mufflers, however takes creative installation. Take a look at other generators with very quiet mufflers for ideas (different types of machine may use the same engine so take notice how other types lawn equipment /tools deal with noise ). Some generators are made for camping or use in quiet zones and use other methods for quieting the unit. Still other generators are noisy even with large mufflers. Good luck with your project.
May 02, 2011 | Coleman Powermate Powermate 5000W...
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Need new muffler can't find part #
After much research, it appears you have a 6.5 Briggs & Stratton OHV engine. Find the mufflers part #'s and prices for it here:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=121602-0269-E1&dn=21430006
A guy in South Florida had a used one listed on Ebay for much cheaper. Check to make sure that you actually need a muffler and not an exhaust gasket.
Jul 10, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
How do you pull the carburetor to get to the muffler
Your question raises a couple of my own.
Make, model, and serial number? There are over 300 Homelite models, 230 McCulloch models, Etc. Do you think they are all constructed the same?
Why would you need to remove the carburetor to remove the muffler?
Jan 23, 2010 | Garden
Where will I find the spark arrestor for the Ryobi RLT30CES and how do I clean it?
Hello dejbutcher:
The Spark Arrestor Screen is in the Muffler. It is Either Attached to the Outside of the Muffler or Inside the Muffler. If Mounted on the Outside, then you can Remove the Bolts Holding the Cover and Simply Remove the Screen and Clean it or Replace it with a New Screen. If it is Inside the Muffler and the Muffler is a Sealed Unit and Does Not Seperate, then a New Muffler is Required. If the Muffler will Seperate, then the Screen can be Cleaned or Replaced just like the Extrernal Spark Arrestor Screen.
You can View a Breakdown of this Unit at this Site Addy; http://www.ryobitools.com/parts and Select "Go to Ryobi Outdoor Parts Store". Now Select "Repair Parts Catalog". Select I Agree to Terms. Now Enter the Model Numbers and Click Search. Now Double Click on you Model in the Results Area.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Ryobi Garden
Gears on my stick shift are starting to feel hard to shift
I would take it to a shop and have some general routine maintence done on it fluids, filters, spark plugs, etc.
Apr 03, 2009 | 1998 Saturn SL
Garden Logo
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
