Question about RaidMax Computers & Internet
New power supply won't turn on
My PC was powering itself down and I replaced the Ultra 350W PSU with a RaidMax RX630Z 630W PSU and pluggd in the cables in the same locations the previous power supply had connected. However, when I try to power it on... absolutely nothing happens. It is still dark.
SOURCE:
preachw996
  • 1179 Answers
SOURCE: Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Posted on Dec 21, 2008
SOURCE: Problem with new Aerocool Zero Db 620W PSU
plug it directly into the wall dont use power bar or check for 120 / 220 volt switch
Posted on Feb 11, 2009
  • 34 Answers
SOURCE: New power supply problem
One of the reasons that this could be is that the power supply doesn't have enough power to power everything. Trying exchanging it for another one that has more watts. If this is an exact replacement as far as the wattage goes, then your problem may lie else where, and you may want to take it to a reputable local computer repair shop for further inspection.
Posted on Feb 19, 2009
  • 415 Answers
SOURCE: Power Supply Replacement
It never hurts to have a larger power supply, yes it have use 100watts more in a hour. But you should have better reliability with the 450W.
Mark
Posted on Apr 05, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: My Codegen Switching Power Supply 350W Model 300Xi
Using 115 volt or 208 volt switch?Found on back of supply
Is the fan clog with dirt and is it turning?
Check your wiring as some supplys can be wired for 115 volt or 208 volt.you want 115 volt.
Posted on Jan 16, 2010
I have this card and do not show video nothing and without the car I try to install the driver and software Cd but don't want to run. is my Pc totally incompatible? dell studio XPS 8000 thanks
Not neccessarily. Depending on the power rating, your 350W PSU may not be strong enough to power this card.
I would get a new PSU anyway. They are cheap nowadays and yours is very small. It will barely be enough to boot up the computer and its devices let alone a power hungry graphics card
Feb 24, 2015 | XFX Core Edition AMD Radeon R7 260X 1GB...
Psu wont turn on
Test the PSU. Unplug it from the motherboard and then with nothing connected, short the green wire to any ground (usually a black) using a paperclip and it should come on and stay on if the problem was with the motherboard/computer but if it shuts down, then you know the problem is the PSU itself.
If the PSU stays on under no load, then one possibility is you had too much connected to it and it shut down as a protective feature. The Bios would not beep if the PSU is shutting itself down. Also make sure you have the internal speaker connected. It's possible you just can't hear the beep because there is no speaker connected or it may be connected to the wrong place.
Don't throw away a defective power supply. It is worth a couple bucks as parts for an electronics enthusiast. Keep it out of the landfill.
Jan 16, 2013 | RaidMax Computers & Internet
How can i repair a power suply
9 times outa ten there is a small 2.5 amp fuse inside.
you will have to desolder it and er-solder a new one in.
Oct 07, 2010 | RaidMax 350W Power Supply...
My computer don't turn on at all and the power supply seems to work fine!
make sure all of the internal electrical leads connecting from PSU to your hard drive,cd drive,floppy drive are not faulty or just replace them they're cheap IDE, SATA leads aswell
Jul 21, 2010 | RaidMax 350W Power Supply...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
Remove the pulley of a power steering pump from 1990 gmc 350
Autozone rents the specialized puller for free, there is a special puller just for power steering pumps.
Nov 08, 2009 | RaidMax 350W Power Supply...
Ultra 350 Power supply very loud fan
It's not normal for the fan to be loud, what makes them loud is either a build up of dust on the fan blades or the bearings are going on the fan itself.
If the PSU is working fine then you can replace the fan itself from an identical PSU. It does mean taking the PSU out of the computer and fitting the fan yourself.
Alternatively you can purchase another PSU.
Regards.
Aug 30, 2009 | Ultra (9PA3501609) 350-Watt Power Supply
Thermaltake Power Express 450 problem: Have to wait one hour !
The problem is obviously with the Thermaltake PSU.
I'm thinking either it's not turning on at the same time as the primary PSU, or it isn't feeding stable, clean voltages to the graphics card. Either calls for a return to the manufacturer.
Now on to getting your video working. What you want is enough power going to your video card. Try connecting the card to your primary PSU instead of the Thermaltake one. 630W might be enough depending on how reliable the brand is, as they often lie.
If it doesn't work, getting a more powerful primary power supply will fix the problem. Go for 750W+to be safe.
Apr 11, 2009 | Thermaltake Computers & Internet
NEW ULTA V Series 350w power supply .
yes that fan should plug into the 4 pin MOLEX off the PSU.
Hope this helps
Jan 05, 2008 | Computers & Internet
Newly installed, first boot up PSU problem
If it's a new PSU, then return it for a replacement...Even online distributors will replace faulty units. And since your old PSU works on it, I'd have to say it's the new PSU that's faulty. Did you make sure that it's the right PSU for the CPU that you have? (As there are PSU units for AMD and seperate ones for Intel...Intel just has a additional power cord to connect to the motherboard)
Apr 06, 2007 | RaidMax Aurora RX580 (RX580F) 580-Watt...
Computers & Internet Logo
Top RaidMax Computers & Internet Experts
Alun Cox
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
