Question about Sharp LC-42D64U 42 in. LCD HDTV
Digital audio on lc 42sb45u
Connecting cable for digital audio will not fit in. White peice inside slot should it pull out or should cable fit in with this piece?
5 Suggested Answers
  • 814 Answers
SOURCE: Sharp LC-42SB45U
You Have to check The owners manuals for both products to see if you are using the correct switching method to use your television with the surround sound.There is usually a setting for each unit that must be set for the correct signal path to the amplifier output to the speakers. The way to test this out is to use the first input on the surround sound unit for the television. Hook- up the output of the sound for the television to first input on the surround sound amplifier.Set the surround sound amplifier to the first setting and test to see if it is working. If still not working check the televisions sound output section in your owners manual and see if you have to set the output to the line out sound and turn off the television speakers output.If this is true make this adjustment with the on screen menu and test the sound again.If still no sound output there may me a problem with the output sound section of you television. You should then check the Sharp website for the frequently asked question and troubleshooting sections to see if similar problems have been posted for this problem and have answers.If all this fails you should contact customer service for both units and ask for technical assistance for your problem. Hope this helps you with your problem.
Posted on May 12, 2009
  • 380 Answers
SOURCE: LC-42SB45U will not find channels from setup Auto
Make sure you getting a good signal and that you are properly connected to the tv. If all else fails, look into replacing the main board.
Posted on Dec 13, 2009
  • 28 Answers
SOURCE: I have a Sharp model
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Rjn
Posted on Sep 20, 2011
UpGrade
  • 113 Answers
SOURCE: Have a Sharp LC-42SB45U green light is on but no
This is the Actual solution, not a try this deal. You need soldering experience, and a multi meter. First pop the back case off the tv and look to the left, you'll see the inverter. It's got 8 or so pink and white connections on it and a few other wires and a ribbon cable. Take all of that off carefully. Now take out the screws that hold the board on. Once you have it in front of you look for the power connector on the far left above that you'll see two fuses. F1 and F2. Check both sides of F1 with an Ohm meter. Most likely it's blown. Replace this fuse with another one and your TV will be back running again. If you're feeling really clever you should touch up the cold solder joints on all of the inverters, and across all of the capacitors, some of mine were cracked.
Posted on Nov 11, 2011
Can't open door from inside
There isnt one it just hooks around handle and lock mechanisem but its a realy heavy cable or wire is it in its slot as if its not fitted correctley on the door handle part it will be slack there should be a small white plastic bit on the end of the outer cable part this should fit in a slot on the door handle bit its a bit like the brake set up on a peddle bike
Dec 02, 2017 | Mercedes-Benz C230 Cars & Trucks
Do i need a digital audio cable to connect to samsung led tv to make sound bar work
You will need some type of cable, Look at the ports on your tv and soundbar.
If you see both have red and white ports then all you need is red and white audio cables.
If you see both have auxillary input ports then all you will need is a standard aux cable. (3.5mm is the standard)
If you see HDMI slots then you can use a HDMI cable.
If you see a digital audio input port then you can use a digital audio cable.
Luckily makers give us several options on how we want to configure our systems and the variability of the ports allow us to fully customize it. I hope this helped. All of the a fore mentioned cables can be found at your local electronics/department store.
Feb 07, 2011 | Philips Audio Players & Recorders
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
The "ribbon" pulled out
If you mean one of the ribbon cables, they usually go into a thin clip. This clip often has a releasable pressure fitting. Look for where you pulled the cable from and see if the fitting is two toned. If so use your fingernail to either pull the flap forward, to back.. various types. Place the cable back into the slot and press the clip back down.
If the ribbon is a (usually) white cable with a hard clear or blue end, then it likely goes into a solid pressure fitting. Just grab the hard plastic tab and push it back into the slot.
Feb 15, 2009 | HP Officejet 7310 All-In-One Printer
Connecting an hd-tv
use optical or composite digital audio cable only from tv to receiver because with rca (red and white) you get stereo only
Jan 11, 2009 | Kenwood VR-616 Receiver
HOW DO I ADD A BLU RAY PLAYER TO PHILIPS HTS6500
If there is some type of audio cable running directly from the Vizio to the HTS6500, then you can just plug the Blu-Ray player into the TV and you're set. If the current audio cables are running instead from the cable or sat box to the HTS6500, then you will need to run audio cables from the Blu-Ray to the Philips HTS6500. There are 3 available audio slots on the Philips - the Digital Audio/Coaxial IN, AUX 1, and AUX 2. If the Digital Audio slot is already taken, then you will have to run red and white cables from the Blu-Ray player Audio OUT to either the Aux 1 or Aux 2 on the Philips (I am making a huge assumption that your Blu-Ray player has red/white audio outs). If the Digital Audio slot on the Philips is not taken, then run a digital audio cable from the Blu-Ray to the Philips. Good luck!
-Tha Mp3 Doctor
Jan 02, 2009 | Philips HTS-6500/37 System
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Sharp LC-42D64U 42 in. LCD HDTV Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
