Question about Dryers
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
On auto cycles the timer seems to go faster than normal. It would start at 55min for example, but then go down fast and be done in 15min with the cycle while the clothes are still wet. The weird thing is that if we pick the exact same setting on a manual cycle, it would run the correct amount of time and dry the clothes. So what is the difference between these cycles? Is it just some type of sensor used on the auto cycles? The timer works manually, so it couldn't be the timer. We can use it on manual cycles but it woudl be nice to use the auto ones again. Thank you for any suggestions.
    President:
  • 2,468 Answers
Try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Posted on Feb 18, 2012
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Aouto dry timer doesnt shut off system when clothes dry
It could be as simple as cleaning the sensors with rubbing alcohol. Build up from dryer sheets will cause erratic operation. It could also be a bad gear or dirt in the timer. Eric
Jun 19, 2009 | Whirlpool Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
Dryer won't shut off after cycle
i got to know what cycle you are using the timed dry or the auto cycle timed dry you may have a bad timer if auto dry it coult be the auto dry resistor or it could be a clogged vent.
Jan 19, 2009 | Maytag PYG2300A Gas Dryer
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Sep 15, 2008 | Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
