MANUAL FOR hf 0034 pELONIS FAN FORCE HEATER
PELONIS MODEL 0034 MANUAL
3 Suggested Answers
  • 12 Answers
SOURCE: Unit won't turn off - it's a Pelonis HF-0034
Sounds like a faulty thermostat switch.
Posted on Dec 16, 2008
SOURCE: Pelonis HF-0034 turned off 10 sec after starting; won't restart
We had one of these heaters also. Used for one year for short periods of time to heat an extra room. Went to plug in and nothing. My husband took the bottom plate off to see if there was a blown fuse and instead found a burnt wire, which had melted part of the plastic disk. If I were you, I would throw it away and get something else. This model is discontinued and I am sure for many reasons. I would look for a different manufacture also. I called customer service and after being told to bad, the man hung up on me. Great customer service. :(
Posted on Feb 05, 2009
Purpose of left button
Hi Harvey,
Left button of what tool?
Sep 28, 2016 | Pelonis Heater. 1,500-Watt Digital Fan...
HF-0020T Fan Forced heater
If the symptoms are as described, the heater probably has failed completely.
Nov 01, 2012 | Pelonis Heating & Cooling
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
Looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
May 15, 2009 | Pelonis Heating & Cooling
I've been through 4 or 5 of these (and similar models) with the same problem after anywhere from 3 months to 1 year of use. It appears to be an overheat condition. Unplugging for about 10 minutes resets the overheat protector, but it will overheat again after running a short time.
Sometimes you can extend the life by blowing out the heater with compressed air, especially around the electronics at the very top and the contact points at the top of the circular heating element.
I'm currently trying a Lasko 755320 from amazon.com -- cheaper, more features, better user interface, more heat, and it almost has to be more reliable than the pelonis.
Dec 26, 2008 | Pelonis HF-0019 OSCILLATING HEATER - OFF...
Hf-0022
tap the heater gently. i say GENTLY, in the area of the on switch. try this several times. usually the tip over mechanism will stick. i say gently.
Nov 21, 2007 | Pelonis HB156T Ceramic Compact Heater
Heating & Cooling Logo
382 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
