Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
795.78402.800 Have a model 795.78402.800 kenmore. worked fine, moved it upstairs, and took out the filter to check, and now it won't cool. I reset the filter and have the refrigerator panel set to 40 degrees. but it wont cool. Have the manual, but don't know what to do.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 1122 Answers
SOURCE: Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Posted on Oct 14, 2008
projdoc
  • 2237 Answers
SOURCE: Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: kenmore refrigerator model 106.54592400 wont cool.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 01, 2011
Beeps but will not work
There may be an electrical interlock that prevents your air conditioner from running without a filter in place.
Oct 25, 2017 | Kenmore Heating & Cooling
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
I moved into a place that has a MasterCool Evaporative Cooler on the roof. The ownstairs is quite comfortable so I really only need to cool the 2nd story.... it seems as if all the cold air settles...
jbrown - Hot air rises, Cold air falls. If you have ceiling fans upstairs, turn them on to run counterclockwise at highest speed you can stand. Make sure all the windows are closed upstairs. The ceiling fans will help to keep the cool air upstairs and pull some from downstairs.
If you don't have ceiling fans, invest in a box type fan that you can place at the head of the stairs (that's the top of the stairs) run it on HIGH and it will act like an exhaust fan, by pulling cool air upstairs. It may take a while, but it will help cool the upstairs to some degree.
Hope this helped you. Please let me know. Thanks.
Jun 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
162 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
