Question about Brother HL4040CN Laser Printer
How to change the film fuser
How to change it?
  • 140 Answers
Please refer video "How to replace fuser Sleev"
Similar to HP fuser film replacement you can replace Brother HL4040CN
Posted on Feb 18, 2012
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Our HP Laserjet 2420 printer is printing with black lines, can you help, we have cleaned the head
First try to change the cartrigde with a new one,if the problem persist in the main part you have a problem with the fuser (you need to replace the fixing film).Fixing film is an inside track fuser, fuser can change separately or altogether.
http://www.precisionroller.com/img/J3388.jpg this is the fixing film.First try to change the cartridge!!!
If i have been useful please give me a vote :).Thanks
Apr 06, 2011 | HP LaserJet 2420 Printer
Display shows "system Error E007"
This is a error on the fuser unit (E007 Fixing film rotation error).
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Normally you must change the fuser to resolve it.
Bye
Feb 18, 2011 | Canon iR 2016i Black and White Copier
Printed copies come out smudged, and raised down far right hand margin, feels raised to touch and print comes off , brand new HP cartridge put in but still having problem
You need to either replace your fusing unit or have someone replace just the fuser film. This is somewhat common on HP printers. The fuser film is like a teflon non stick "sheet". When they start to go bad this is what happens. They do not fully fuse the toner onto the page so the print will rub off. The fuser is pretty easy to change so either get yourself one, or call your local printer service company and have them change it out. I usually just do film replacements because it is cheaper. About $150 for a film change VS $250 and up for a fuser unit swap.
Good Luck and Thank You for using Fixya.
Sep 13, 2010 | HP LaserJet 2430n Printer
Double images and dirty copies on left side of paper
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. If you have a spare toner, even an empty one you can shake a little and try it to see if the double image goes away. If a different toner does the same thing then it is the fuser film. Now you can change you own fuser if you wish. Just don't let a service guy come out and tell you that you have to replace the whole fuser. You can have them replace just the fuser film because the rest of the fusing unit is usually just fine. I do fuser films all the time. $50 to $80 for a film vs. $200 and up for a fuser.
Apr 20, 2010 | HP LaserJet 2420 Printer
Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Apr 09, 2010 | HP LaserJet P3005n Printer
Paper jammed.sheet stuck approx 9cms out at top.
The problem is the fuser. Lower pressure roller is damaged. Possible wear and fuser fixing film.
can change throughout the whole fuser
RM1-0661-040 ---- HP LJ1010 220V Fuser Assembly
RM1-0660 ---FUSER - 120 Volt Fuser Assembly
or parts of this
http://www.precisionroller.com/search.php?q=hp+1010&x=12&y=5
FUSER - Lower Pressure Roller :  RF0-1002
FUSER - Fixing Film Replacement Sleeve : for hp 1010
good luck
Dec 13, 2009 | HP LaserJet 1010 Printer
We have put a new toner in but still we are experiencing lots of horizontal lines??
Nov 17, 2009 | HP LaserJet P3005n Printer
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Brother HL4040CN Laser Printer Logo
346 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
