Question about Xerox Office Equipment & Supplies
Fault/error 116-324 workcentre 133
4 Suggested Answers
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
  • 2072 Answers
SOURCE: Xerox Workcentre7242 fault/error 116-324. About 2
That indicated the machine is not reading the DIMM network chip.
I would think removing the memory chip , cleaning it and reinstalling it would resolve the issue. It is possible the network board is bad. I suspect just an iffy connection with the DIMM memory .
Posted on Jul 09, 2010
  • 304 Answers
SOURCE: I have error on my
116-324: Controller Error (Illegal Exception)
To access Service Mode, press Up and Down Arrows at power ON.
Go to EEPROM Test
EEPROM Test
? Start
? Processing
? Check OK
Performs write/read/verification of the test patterns (0xff, 0xaa, 0x55, and 0x00) on one byte at every 0x400 from the first address of EEPROM.
Posted on Sep 14, 2011
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
How do I clear fault code 016-311 for workcentre 7345
That error indicates the scanner is not installed. Check the connection from the scanner to the main ess board and reseat if necessary. If cable is damaged, replace with part number 117K38440.
http://www.iteminconline.com/117k38440_117k38440-xerox-workcentre-7425-iit-controller-cable.htm
Mar 12, 2012 | Xerox WorkCentre M128 Copier
What does fault code on workcentre 7345 004-350
I face an Error code problame 004-350 please told the relief of this code
Mar 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Workcentre 4118 open heat error
Bad fuser module. There is a web mesh heater in that heat roll that goes bad.
Jan 16, 2010 | Xerox WorkCentre 4118X All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Model xd 130 df: I am getting error notices H and 4 and I can't figure out what they are and /or how to correct.
This should correct that.
> Support & Drivers > WorkCentre XD130df Digital Copier - Laser Printer Support > How To Clear an H4 Code Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 18, 2008 | Office Equipment & Supplies
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
