Question about SanDisk Sansa e250 MP3 Player
Hangs on startup unacceptable!
I was given the Sandisk e250 last Christmas and it hasn't worked since June or something. I have read many with the same trouble. This is the second mp3 player that has crapped out way earlier than it should have meaning just a matter of months.
When I boot it up, I get the Sandisk logo and the blue ring lights up but thats it. I also cannot find a battery.
  • jazznutz Dec 21, 2008
    Thank you very much for the reply. I got my player to work with a similar procedure and it has been working perfectly ever since,no battery needed. I am so happy to have it back.
    FYI-I also had to change the upload setting of the USB mode to MSC instead of MTP. I am afraid to set it to MTP now. I am able to add files by drag and drop now which is easier anyway.
    The problem with most of these directions is getting it to boot at all because pluging it in did not even do anything unless the program was open. Its a catch 22.
    Any I'm fine now so if you are having this problem DO NOT GIVE UP on it. Keep trying all these things until you get it. Half of it is knowing if a fix is possible or you you are wasting your time. Does that make sense?
    Out
    Arthur
  • chand d Dec 22, 2008
    i have same problem since long and still trying to fix. first of all, while connecting with computer, it does not identified. I will be thank ful if some body could let me know how to fix my e 250 step by step.
  • 8,596 Answers
Most mp3 players don't make it a year - extremely high failure rate:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
Hanging
Reset, firmware upgrade
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk c 100 mp3
Try to reset your device by holding the menu botton and the back...then go under device manager to uninstall the device...then unplug your device and plug it back again...then do a firmware upgrade on your device...
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Jan 04, 2008 | SanDisk Sansa e250 MP3 Player
No driver
u may need to update something on either ur computor or mp3
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 format??? HELP, PLEASE!
No You Don't Have To Converter The Tracks. It Depends On How You Put The Tracks On Your Sansa, Do You Drag And Drop Or Do You Sync With Copy To Device In Windows Media Player 9, Or Sync In Windows Media Player
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk Sansa m240 1 GB
My sansa did the same thing. I registered it on sandisk.com and they are sending me and new one, so I suggest you do the same.
Aug 15, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 keeps retarting
you should try formating it. when you plug it into your computer... go to my computer right click on your mp3 player name under " devices with removable storage" click format. make sure nothing is checked. and then press start. wait till its done, and it should work. good luck. i can use some to..
May 11, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't work
I had a e260 and i thought i might share this with you. They got recalled, because ofa software malfunction. That might be what is wrong with yours, even though it's a different one it seemed to me like they were still getting the bugs out beause i upgraded to the e280 and i have to take it back too for software problems...
Apr 07, 2007 | SanDisk Sansa e250 MP3 Player
My player(sandisk sansa e250) doesnt play any track
I solved this problem by formatting the player. But I still have a problem that my computer doesnt detect the player in MTP mode.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
