Question about Fagor Coffee Makers & Espresso Machines
Fagor cr-22 is not working and showing 3 flashing lights alternatively left and right? what is the problem
Occurred after we clean the unit with a calcium remover
  • jacques saint-pierre Feb 18, 2012
    thanks to Emily, but i think that i might have damaged it already. Does the error message mean anything to anyone?
You should always use just about one tablespoon of white vinegar added to a potful of cold water, poured into your coffee maker, followed by one full pot of plain cold water to rinse thoroughly.....I think using at least 2-3 full pots of cold water to rinse should fix the problem. Of course you realize you have to have the pot on each time you pass water through it, as if you were making coffee. I think calcium cleaaners are too harsh otherwise. destinie1106@gmail.com
Posted on Feb 18, 2012
64 Chevy electrical problem. Ammeter flutters and lights flicker.
Could be the alternator with a bad or failing diode or a bad phase,there are 3 phases making AC which is converted to DC.
Supply your own field power to the alt with the regulator unplugged.Lights still flickering?replace alt.
Apr 08, 2017 | Chevrolet Cars & Trucks
Tip
Wiring Diagram Kawasaki GPZ 750
Kawasaki GPZ750 (ZX750) Turbo North American models.<br /><br /><img src="suzman_10.JPG" /><br /><br />1 - Right turn <br />2 - High beam<br />3 - Warning light<br />4 - Headlight fail<br />5 - Neutral<br />6 - Left turn<br />7 - Boost Guage <br />8 - Tach light<br />9 - Tach/volt switch<br />10 + 11 - Speedo lights<br />12 + 13 - Illum. lights<br />14 - Spare connectors<br />15 - LCD + warnig lights<br />15 + 16 - LCD illum<br />17 - RF indicator<br />18 - Horns<br />19 - Headlamp<br />21 - LF indicator<br />22 - Reserve lighting unit<br />23 - Hazard switch<br />24 - Indicator switch<br />25 - Horn switch<br />26 - Dimmer switch<br />27 - Starter lockout switch<br />28 - Neutral switch<br />29 - Side stand switch<br />31 - Oil pressure switch<br />32 - Alternator<br />33 - Regulator<br />34 - Solenoid<br />35 - Starter<br />36 - Battery<br />37 - Junction box<br />38 - LR Indicator<br />39 - Stop/tail lamps<br />40 - Stop/tail lamps<br />41 - RR Indicator<br />42 - Injectors<br />43 - Engine temp switch<br />44 - Boost sensor<br />45 - Fuel pump<br />46 - Air temp sensor<br />47 - Throttle sensor<br />48 - Main pump relay<br />49 - Fuel injection control unit<br />50 - Rear brake switch<br />51 - Pick-up coils<br />52 - Ignition control unit<br />53 - Coils<br />54 - Spark plugs<br />55 - Fuel level sensor<br />56 - Front brake switch<br />57 - Starter/engine stop<br />58 - Ignition<br />
on Nov 22, 2010 | Motorcycles
Fuse box layout for 2005 honda crv
No. Amps Circuits Protected 1
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38 7.5
15
10
7.5
(15)
(20)
_
10
7.5
7.5
10
10
10
7.5
7.5
10
10
20
15
7.5
20
_
_
(20)
20
20
(20)
15
15
20
(15)
20
20
7.5
7.5
10
7.5
30 Power Window Relay
Fuel Pump
ACG
ABS/VSA
Heated Seats*
Front Fog Lights*
Not used
Rear Wiper
ODS (Occupant Detection System)
Meter
SRS
Right Headlight High Beam
Left Headlight High Beam
Small Light (Interior)
Small Light (Exterior)
Right Headlight Low Beam
Left Headlight Low Beam
Main Headlight High Beam
Small Lights MAIN
TPMS
Headlight Low Beam
Not used
Not used
Moonroof*
Door Lock
Front Left Power Window
HAC Option
Rear Accessory Socket
Accessory
Front Right Power Window
Accessory Power Socket on the Center Table*
Rear Right Power Window
Rear Left power window
ACC Radio
ACC Key lock
HAC
Daytime Running Lights
Front Wiper * If equipped
Dec 06, 2013 | 2005 Honda CR-V
Lennox 80uhg3-75a-3 igniter sometimes doesn't light , left LED slow flash, right LED solid.
Should be a trouble code on the panel or in the literature book that came with unit. More than likely it's on the inside or outside of the blower panel. This will indicate Red light on Green light slow flash = what trouble code or issue it's having. Most common problems with a gas furnace is the flame sensor needs cleaning. There is a little rod that sticks down into the flame when the burners ignite. It's the only thing the flames will come in contact with besides the furnace itself. It will have 1 wire connected to it. Clean that rod with a piece of light grit sand paper. Don't take much force to clean it so try not to damage it by shining it to look like new. Cycle and see if it will hang in there. Hope this helps!
Sep 17, 2017 | Heating & Cooling
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
Translating japanese to english on fuse box
is located under the dashboard on the driver's side. The fuse label is attached under the steering column. If something electrical in your vehicle stops working, check for a blown fuse first. Below table outlines detail fuse number, its ampere and circuits protected. honda-crv-interior-fuse-diagram-thumb.png
No.
Amps
Circuits Protected
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
7.5 15 10 7.5 (15) (20) _ 10 7.5 7.5 10 10 10 7.5 7.5 10 10 20 15 7.5 20 _ _ (20) 20 20 (20) 15 15 20 (15) 20 20 7.5 7.5 10 7.5 30
Power Window Relay Fuel Pump ACG ABS/VSA Heated Seats* Front Fog Lights* Not used Rear Wiper ODS (Occupant Detection System) Meter SRS Right Headlight High Beam Left Headlight High Beam Small Light (Interior) Small Light (Exterior) Right Headlight Low Beam Left Headlight Low Beam Main Headlight High Beam Small Lights MAIN TPMS Headlight Low Beam Not used Not used Moonroof* Door Lock Front Left Power Window HAC Option Rear Accessory Socket Accessory Front Right Power Window Accessory Power Socket on the Center Table* Rear Right Power Window Rear Left power window ACC Radio ACC Key lock HAC Daytime Running Lights Front Wiper
Dec 13, 2010 | 1997 Honda CR-V
I can not print. it shows an error messege on the lcd screen 5c00 and green and orange light flashes alternately.
The error code 5C00 is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925)
Nov 28, 2010 | Canon MP520 All-In-One InkJet Photo...
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
FUSE BOX DETAILS
left to right...
1. empty
2. e flashers
3.horn, brake lights
4.clock, trunk light, inside light, radio
5. rad. cooling fan relay (AC only)
6. right side running lights
7. left side running lights
8. right high beam and indicator
9. left high beam and indicator
10. right low beam
11. left low beam
12. reverse,turn signal and inst panel
13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater
14. license plate and glove box light
15. wipers
16. rear defogger
17. heater blower (no AC)
18. cig lighter
19. rad cooling fan (no AC)
20. Heater blower (AC)
21. rad cooling fan (AC only)
22. empty
23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve)
24. inst panel lights, heater control lights
25. reading lamps
26. empty
27. empty
28. empty
Hope this helps...;-)
Apr 17, 2009 | 1992 Volkswagen Fox
Flashing Light
Hopefully just has a jam. Usually people miss them under the process unit (toner) or behind the paper tray. Pull all the way out and look. If you have really looked everywhere you probably have a sensor out of place or dirty.
from manual-- Attention - Flashing  A paper jam has occurred. The cassette is not inserted properly or the paper has run out.
also read page 22-27 in your manual for jam removal
Apr 17, 2008 | Kyocera Mita FS-1030D Laser Printer
Coffee Makers & Espresso Machines Logo
183 people viewed this question
Top Fagor Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Fagor Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
