Question about Radio Communications
What is the talk range of a Motorola P14spa03p2aa walkie talkie?
Just want to know how far of range the other person can hear me from?
  • Radio Commun... Master
  • 1,654 Answers
Line-of-sight you can talk as far as the radio can 'see'. In the real world, with obstacles and curvature of the Earth, this will vary according to your location. General rule of thumb, outdoors with few obstacles, you can talk line-of-sight up to 2 miles. Talking in and out of a building might reduce your range to 1/4-1/2 mile. There will be circumstances when you could achieve great range such as talking from a mountaintop into a valley, you could potentially talk 25 miles.
Height and placement of the antenna determines range. Holding the antenna perpendicular to the ground will give you the most range. Tilting the radio can reduce your range by as much as 2/3s.
Best regards.
Posted on Feb 19, 2012
SOURCE: Motorola Talkabout T5100
Here's a solution finally!! Turn on the radio and press the + button, then while holding it down turn off the radio and then turn it back on after a second, then release the + button. A little icon that looks similar to o))) will no longer be there, which means that the roger feature has been disabled. To re-enable it, turn off the radio, THEN press +, then turn the radio on. Hopefully this helps. It works for other motorola models too, I got this from the manual for the T5500.
Posted on Aug 21, 2007
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Posted on Apr 09, 2009
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
They work close up but not far away
Double check the frequency you have the radios set to, and be certain they are exact. Sometimes when you are on a near frequency you will have range problems. Also, hold the radio upright with the antenna pointed straight up when transmitting. Face the direction you are trying to transmit. Height and placement of the antenna determines range. Handhelds can generally talk as far as they can see. Obstacles between you and the other radio can reduce range, including the body fluid of the person wearing the radio. And lastly, be certain you are using good batteries for best performance.
Best regards.
Dec 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Is kenwood walkie talkie and motorola walkie talkie on the same frequence
If you are talking about FRS radios, the answer would be yes. If you are talking about business radios, it depends on how they were programmed. Business radios have many frequencies available.
Oct 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Talking
See if the one radio that doesn't hear the other has a PL tone programmed into it. If both radios are not programmed to the same PL tone, then one will not hear the other. Consult your owner's manual on how to do this.
Regards,
Longshorts.
Jun 24, 2009 | Motorola Walkie Talkie 2-Way Radio
Voice activation
The Motorola T-5000R does not have VOX capabilties. Page 23 in the manual explains this.
Here is the Link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
HiTech Wireless
Mar 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
Dec 19, 2008 | Motorola Walkie Talkie 2-Way Radio
Cellphones with walkie-talkie features
Nextel uses WIDEN (network) for most two-way communication. Some, if not all, have DirecTalk. This is a feature which allows communication as a short range radio allowing everyone on your channel in the same mode to hear you.
Nov 06, 2008 | Motorola Walkie Talkie 2-Way Radio
Walky talky
A walkie talky as we called them, back when we were younger - and hell we probably still do in some respects, hence the fact my friend still refers to her cordless phone as a "walkie talky" and the principals haven't changed that much.
The common old Walkie Talky or CB radio use what we call a half duplex, that means only one person can talk at a time. We are talking and listening on the same channel.
Cell phones are full duplex, meaning two way conversation, and this is simply listening on one channel whilst talking on another, so the basic principal is basically the same, just a little more sophisticated.
Walkie-talkie typically has one channel
CB radio has 40 channels.
Cell phone
can communicate on 1,664 channels or more!
I have included a link to a circuit diagram.
http://www.freeinfosociety.com/electronics/schemview.php?id=1870
There is also two links below, building the transmitter & receiver.
Transmitter: http://www.zen22142.zen.co.uk/Circuits/rf/2bjttx.htm
Receiver: http://www.electronics-tutorials.com/receivers/regen-radio-receiver.htm
Trust this helps, and please take the time to rate the answer given, thank you.
Feb 04, 2008 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
186 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
