Question about Refrigerators
I have a Samsung RM25KGSH 4-door fridge/freezer. The fridge works good but the freezer will not go below 5C. the fridge is in impeccable condition so just cannot junk it. would be grateful for an asse
Have got local technicians to look at it but no help. one of them came and changed a copper tube at the back but no help. The lcd screen says -19C but the freezer is stuck at 4-5C
  • 1462 Answers
SOURCE: cannot open the bottom freezer door anymore; it seems stuck
sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
Posted on May 06, 2007
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Posted on Oct 13, 2009
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Posted on Jul 08, 2010
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Fix slanted side of screen on Sony vaio
Hi Linda
You must be old enough to remember the old way of setting up screens. That was when they were CRT's (Cathode Ray Tube).
The large picture tube used to use Deflection Coils on the neck of the picture tube (magnetic coils) therefore requiring adjustments to the alignment of the screen (by adjusting magnetic signal from coils) Hard to Explain any further.....
Cathode ray tube
So.... Modern devices that use LCD or LED or Plasma Displays.
These are all modern Digital devices that do not have any adjustments to be made. Basically it is all coming directly from the Video Memory to the pixels in the screen.
All computer controlled......Ones & Zeroe's 1 - 0
So..... where is the problem?
Probably a loose or broken cable between the video memory and the display. Usually carried over a thin flexible flat copper connector which goes between the gap between the computer and the moveable screen.
When you open your laptop screen & close it... it can eventually crack this cable & therefore some screen dots (pixels) are missing.
To determine location of break. Carefully watch the monitor LCD screen as you open and close to see if it glitches or fixes the problem. Probably someone will have to replace this or some other cable inside.
How to repair Flex cable Flexible PCB type flat copper ribbon cable
Hope this Helps
Please give me a tick? or "Thanks" if this enlightens you!
Cheers
.......Trevor
Sep 20, 2015 | Sony VAIO Computers & Internet
Where to get a copper gas line for Endless Summer 230000 Patio Heater?
Could you use a compression fitting across the break? If you can take a piece of the tubing to local hardware/auto store for sizing to see how snug the brass ring is.
Oct 21, 2014 | Patio Heaters
How do I get my new Samsung RF220 to be cooler in the refrigerator section? The temperature does not go below 52degrees F. It is set at the coldest setting.
Check for deformed rubber boot that runs entirely around edge of fridge door allowing cold air in fridge to leak out. 2nd possibility: Louvers in wall between freezer and fridge may be stuck in mostly closed position. Force them GENTLY to open. That will allow the cold air to pass normally from the freezer to the fridge to give you proper fridge temps. If these two easy cures don't work, here's hoping that Samsung owes you in-warranty service and parts on your "new" unit.
Oct 12, 2014 | Samsung RF220NCTASR 21.6 Cu. Ft....
Why has my sanyo flat screen television only got coloured horizontal lines across the screen?
That might be an issue with the TVs picture tube if it was not one of the LED or LCD TVs. Please get a technician changed it. If it was any one of the LCD or LED TVs, then it would be more expensive than you expect.
Jul 20, 2014 | Sanyo Televison & Video
Have to slam freezer door to clear 88 error codes on samsung refrigerator
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
Mar 10, 2014 | Refrigerators
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
How to fix blurry screen display...
This condition appears when you transfer the pics at pc? If yes, you have a problem with the CCD image sensor and will need contact your service local technician to change this part. If not, its possible that your LCD screen viewer go to bad or some exposure or ISO settign need adjust.
Hope this helps.
Sep 07, 2011 | Cameras
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
