Question about Health & Beauty
Clips for remington speedsetter H-2008 hair roller
Clip
zeusfaber
  • 247 Answers
SOURCE: Remington HC600 hair clipper stopped clipping
This might be as simple as putting a drop of light oil into the gap between the fixed and moving blades. A.
Posted on Jun 28, 2007
  • 62 Answers
SOURCE: Hair Clippers not clipping
All clipper/trimmer blades must be oiled both before and after use. Hold the unit with the blades pointed toward the floor. Put a dab of oil across the front of the blades and turn the unit on to get the oil distributed through the entire blade. Turn the unit off and wipe the blades with a soft cloth to remove any excess oil.
Posted on Jan 07, 2008
SOURCE: Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Posted on Mar 15, 2009
askmannyssha
  • 76 Answers
SOURCE: Please advise how I can obtain a user manual
http://www.youtube.com/watch?v=nYoj6v9XlbQ
Posted on Mar 30, 2010
  • 164 Answers
SOURCE: instructions on how to clip
  • Set the dog hair clippers to the 9-10 setting. Use this setting to clip your dog's undercarriage. Undercarriage refers to your dog's armpits, **** area up to the tail, and stomach.
  • Set the clippers to the 7-8 setting. Clip your dog's legs and paws with this setting.
  • Use a comb to pull your dog's hair away from the eye and muzzle area. Set the clippers back to the 9-10 setting and clip all around his face, ears and head.
  • Rinse your dog with clean water or give him a shampoo to remove all of the excess hair you clipped off. Blow drying him may be necessary if it's during the colder months of the year.
  • Posted on Apr 03, 2011
    Where can I find a manual on how to use the Conair Instant Heat Hairsetter model CHV21C? Thank you.
    Watching a YouTube video on how to use Hot Rollers would be a good idea. I found several for you to see, and she's using Conair rollers, also the same kind I have. I know the clips are difficult to work with but this might help give you some tips! Good luck! My Everyday Hair Tutorial Hot Rollers
    Jan 01, 2015 | Conair Health & Beauty
    My Electrolux Oxygen3 powerhead needs long hair cleaned from the roller. Is there an easier way to get to it than just painfully clipping the hairs and slowly pulling them out? We cannot get the bottom...
    Unfortunately the only way to clear the roller is painfully clipping and pulling. If you do happen to remove the roller, it's really alot of trouble to put it all back together.
    Aug 02, 2011 | Vacuums
    Razor making vibrating noises and not shaving properly - feel like hairs being pulled out. beard trimmer will not cut and will also not clip back down in to main shaver when not needed
    You should try detaching the head of the shaver and cleaning it thoroughly. You should then try oiling it with the oil that came with it, or any lubricating oil that is safe with metals.
    Let me know if this helps!
    May 02, 2011 | Remington Health & Beauty
    I have a remington F7790, a great razor but the foil head keeps popping up and not sitting right whenever i turn it on. does anyone know why or how to stop this
    This problem is because the shaver has not been thoroughly cleaned. There is a build-up of hair particles where the screen snaps onto the shaver which is preventing it from latching into place. Clean it thoroughly and it should be fine
    If you are certain that it is thoroughly cleaned and still have problems, your screen is worn and will need replaced. You will find replacements for model F7790 at shaveroutlet.com. See link below
    http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
    Dec 29, 2010 | Remington Health & Beauty
    I have a remington precision hc-912 hair-trimmer. My 1/4 inch guard broke and I don't know where I can get a new one.
    Use a precision screwdriver and pry the clip up. It is spring metal and will snap back into position upon reassembly. You will have to solder the battery in place. Works on all microscreen shavers supermesh and XLR.
    Aug 31, 2009 | Remington Precision HC-815 Hair Trimmer
    I need to replace batteries in Remington wdf 3500
    Have just opened the same model -
    First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
    Dec 22, 2008 | Remington Smooth and Silky WDF-3500 Hair...
    Dell 1600N printer paper jam
    More than likely you need a new pick up roller. It is located at the top of the tray area in the printer. You will see a black rubber roller with white nylon clips on both sides. You can confirm if it is the problem by removing and washing it with soap and water, then clipping it back in and running a few copies.
    Mar 16, 2008 | Dell 1600n All-In-One Laser Printer
    To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
    P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
    Jun 28, 2007 | Remington HC-600 Hair Trimmer
    Health & Beauty Logo
    37 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
