Question about Brother DCP-340CW All-In-One InkJet Printer
Won't recognise new ink cartridges
Ran out of yellow ink; Cartridge replaced; Message, "Install yellow ink cartridge"; Faulty cartridge? Changed it again; Message again, "Install yellow ink cartridge"; Needless to say, checked the fit of the new cartridges, checked they were full, clean etc. Any known issues or solutions?
Mix-it-up
  • 832 Answers
SOURCE: Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Posted on Sep 07, 2007
Mix-it-up
  • 832 Answers
SOURCE: new ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Posted on Jan 28, 2008
Mix-it-up
  • 832 Answers
SOURCE: MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Posted on Mar 04, 2008
SOURCE: i have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Posted on Nov 15, 2008
SOURCE: says the yellow ink needs replacing,have a new ink cartridge in
pulled plug, removed yellow cartridge, cleaned point where yellow ink goes in, put plug back in and it worked.........Thanks
Posted on Jan 28, 2009
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
I have replace the yellow color cartridge on my HP Photosmart C6100 several times and it still says its empty.
clean the metal pins on the ink cartridge amd the pins in the printer were the ink cartridge geo's
Sep 15, 2008 | HP Office Equipment & Supplies
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
I need to make the ink carriage move over so I can replace the ink cartridges inmy workforce 840. Online here it says "hit theink button" what the heck does that mean? Where is this ink button?...
this is out of the manual
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the
ink remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If you're replacing a cartridge before you see a message on the LCD screen,
press Setup, select Maintenance, then select Ink Cartridge Replacement.
3. Raise the scanner.
4. Open the cartridge cover. Then squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets
into your eyes, flush them immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package, shake
it gently four or five times. Then remove it from
the package.
6. Remove the yellow tape from the bottom of the
ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of the
cartridge. This can damage the ink cartridge.
Sep 01, 2011 | Office Equipment & Supplies
Message says: "To print in
Clean the connection and reinstall the cartridge -
Clean them with proper spirit.
Nov 08, 2010 | HP Office Equipment & Supplies
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
Brother DCP-340CW All-In-One InkJet Printer Logo
55 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
