Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
V3 got wet
By Thorpedo06 on Aug 20, 2006
my motorola V3 got wet as i was texting in the rain :S i thought nothing of it, and put it in my damp pocket, next morning i woke up and the keypad lights up but the screen remains black. ive removed the battery and put it on charge bu t still wen i open up the phone, the keypad lights up. what shall i do?!
Same Problem
Jan 06, 2009
-   I fell in the lake (fresh water not ocean) with my Nokia, I took the battery and chip out IMMEDIATELY then dried the phone it with the hairdryer multiple times (even after I was sure it was dry). Even at the risk of overheating the phone. What have you got to lose? I didn't put the battery back in (don't want to fry the wet circuits) for another day or so but kept a three hour routine of drying with the hairdryer. Finally re-installed the battery (and the chip) It's been working perfectly for a year and a half since! If you dropped your phone into SALT WATER, that's much worse! Immediately remove the battery and then submerge it again in warm tap water to try to remove the salt. Rinse again, then shake it out and try drying it. AGAIN - What do you have to lose?
Tim Carroll
-   tcarroll859
Apr 29, 2008
-   I had sat my phone on the table not knowing there was a little bit of water on it i got it off as quickly as possible. Now the screen will turn white and it wont turn on. It does work but sometimes the screen will just keep turning white.-   jovi16
Best Solution
posted on Apr 01, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Take out battery ! leave case open set phone on top of a lamp shade wire support with a 50 watt lamp No! larger turn on lamp for 2or 3 hours to dry out the phone . I had to this 2 times it worked for me
Solution #2
posted on Jun 27, 2007
Somewhat Helpful)
phoinix
Rank: Wiz
Rating: 78%, 61 votes
m8
water and fones dont go together.and drying the fone out could get it to work for a short time and then you will have problems
my advice is try these guys they got gr8t tech sapport i know cause i abuse it on a dayly basis.and they very good at fixig waterdamaged fone
http://www.mobilephoneservicecentre.co.u...
Was this helpful?
Yes
No
Solution #3
posted on Sep 04, 2006
Somewhat Helpful)
harley12
Rank: Master
Rating: 81%, 295 votes
sorry to say this but a wet phone is ruined. You will have to take it to a tech at your phone server. They will either repair it or you will have to get another one. Water and phones do not go together at all. Sux.
Was this helpful?
Yes
No
Solution #4
posted on Jan 06, 2009
Not Rated)
tcarroll859
Rank: Apprentice
Rating: 0%, 0 votes
Tim Carroll
Was this helpful?
Yes
No
Solution #5
posted on Jan 05, 2009
Not Rated)
azn_gal_101
Rank: Apprentice
Rating: 0%, 0 votes
i dropped my motorola v3 in the bath twice before and just the other day aswell. now it doesnt work. last time it didnt work 4 months so i bought a new phone. i checked it months later and it worked! now i hav 2 leave mine 4 a few weeks, laid out, battery out case open etc and itll be alright. it might take months 2 dry out, but once its completlely dry itll work.
Was this helpful?
Yes
No
Solution #6
posted on Jul 23, 2008
Not Rated)
lesliem825
Rank: Apprentice
Rating: 0%, 0 votes
went swimming with phone got soaked...took out battery and sim...laid in sun looked ruined...came home charger worked.... powered on after charge but wouldnt stay on you could see water in screen grey and light was dark... keypad wouldnt work ... put on heating pad for night on high heat with battery out ..in the morning ran fingers HARD over keyboard after it powered on because keys still wouldnt work ... they started working as I did it now it works FINE like new ...heat is the answer and patience the heat hastens drying time
Was this helpful?
Yes
No
Solution #7
posted on Jun 06, 2008
Not Rated)
The Mi
Rank: Apprentice
Rating: 0%, 0 votes
Ok,
So my rich friend dropped his Razr Dolche Garbanna edition in some soap water, let it dry and gave it to me. It will turn on but every button opens the ring tone volume control except for the power button. it can get calls but can not answer them unless it is closed when the call comes in. any suggestions on how to fix this?
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
I have set 4 daily alarms on my V3, and some times they do not go off! I've checked and they all... (More)
Answer
my keypad is not working just on and off button working now wht can i do sir?
Answer
I get a 'GPRS network not available' reply when I try to access my internet browser in my Motorola
Answer
my screen on my motorola razr went black and i've tried everything i could think of. Do you have any... (More)
Answer
I cant acess my motorolla razor v3's menu i want to format the phone usingh motorolla phone tools... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
in , CA
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
