Question about Motorola Mobility H350 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
Have the Motorola H350 device, but cannot find the manual. I have a new RAZR phone and understand from its phone manual that I need to put the Blue Tooth in pairing mode How do I do this?
Thanks!
Kevin
  • kagcomm Oct 26, 2008
    Believe it or not, in making sure of my own phone model and realizing I'm a dork (I don't have a new RAZR, though I'd swear it is what I had been told at the store), I managed to find the process. So to anyone who ends up with the same question, copy and paste the following link to a new tab:
    http://motorola-global-eng.custhelp.com/...
    Basically, follow the instructions in your phone manual to connect to a bluetooth device while your H350 device is off. After you have turned power to bluetooth device on in your phone, hold the power button down until the light is steady (not flashing). Then on your phone, you will probably have to select an option that says something like "Add device"; once the H350 is found, select it and you should be good to go.
  • 4 Answers
First switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Posted on Oct 30, 2008
What is my pass key for H350
motorola uses two pin pairing codes for their blue tooth devices they are as follows,0000,or 1234 there are two other codes for blue tooth devices as well they are as follows 1111,or 9999 glad to be of assistance.
Feb 26, 2011 | Motorola Mobility H350 Wireless Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
The phone with which my H350 Motorola wireless head set was paired , got lost. How to pair the head set with my new HTC phone
you have to hold the button on the top till the blue stays on then go in your phone to the blue tooth settings and search for the device it should find it and be paired again
Nov 27, 2008 | Motorola Mobility H350 Wireless Headset
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola blue tooth pin code
Yes there is a universal code. It is 0000. That is four zeros.
Hope this helps :)
Oct 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Discoverable Mode
Here is the on-line manual: http://www.motorola.com/mdirect/demos/how2_h3/main.html -First off make sure the headset charges for at least two hours. Also make sure theindicator light turns on indicating charging is occurring. -After the charge is complete you will need to refer to your phones manual to pair the headset to the phone. The discover mode is a mode the phone goes into not the headset. I don't have an LG8600 nor can I find a manual on-line so I can't help you with that part. If you still need assistance let us know and please don't forget to rate the posting.
Jan 23, 2007 | Motorola Mobility H3 Bluetooth Headset,...
Motorola Mobility H350 Wireless Headset Logo
315 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
