Question about Pentax K1000 35mm SLR Camera
My Pentax K1000 won't flash when taking the picture
All i have is a minolta flash. do i need a cord to hook up the camera body or something?
    Champion:
  • Pentax Expert
  • 225 Answers
Questions: is the flash fully seated on the hot shoe, are the batteries in the flash good, finally does the flash fire on another camera. My K1000 would not fire any flash on the hotshoe nor using the PC plug it needed a CLA.
Posted on Nov 28, 2016
SOURCE: lens damaged camera dropped camera
"To get the lens to retract, we tried to do a slight twist over to the left (looking at the camera like your the subject - camera lens is facing you). Sure enough it went back in! But now it has trouble focusing. That's another question now. Darn thing...we'll see what else we can jimmy :-)"
quoted from another solution.
Posted on Nov 17, 2008
  • 185 Answers
SOURCE: What kind of battery does the pentax k1000 35mm SLR camera take?
Yes the K100 uses LR44 or G13. I would recommend the G13
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: Pentax K1000 back door change
I don't have the solution, but it may be in the Pentax K1000 Service Manual that you can get here : http://www.robertstech.com/manuals.htm
Posted on Mar 22, 2009
  • 185 Answers
SOURCE: Pentax K1000 rewinding knob restore
Pentax fan
There is a spring in the way. straighten a paper clip and from the top of the camera push it out of the way while you gently push the shaft up. rotating the shaft helps.
or you could file a little of the shaft collar on an angle ( if it's not there ) then rotate the shaft while gently pushing up. don't bend the spring.
Posted on Mar 27, 2009
Obertelli
  • 3006 Answers
SOURCE: on my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Posted on Mar 02, 2010
Film cartage broke missing parts
To repair this camera will be well over $100; my opinion not worth it. You would be better served purchasing another camera of the same type from ebay. An alternative terrific camera is the Pentax K1000, better yet K1000 SE. The SE has a split viewfinder, easy to focus. The K1000 have microprism that are more difficult to focus with especially in lower light; need good eyes. Then there is the Pentax K2, that at the time was their top of the line camera. All three cameras can be purchased for about $100-ish. Most will come with the Pentax 50mm f/2.0 lens.
Feb 06, 2014 | Minolta Photography
I recently dropped my Pentax K1000....oops! The only damage I noticed was a small dent in the metal side of the lens....hardly even noticeable. But now, the focus isn't working, and the light meter doesn't...
Unfortunately, this is a serious problem.
If the focus ring is not working then there is serious damage inside the lens. This cannot be repaired easily and must be taken in for repair.
As for the light meter, this is slightly more worrying as it is damage inside the body. It could be something as simple as the battery contact. But it could also be somehting more serious.
I would recommend taking it for repair.
If repair turns out to be too expensive I suggest you have a look on ebay. Pentax cameras are available with a wide range of prices and so are compatible lenses. A good upgrade would be a Pentax MX or even an LX if you can afford it. The ME super is also an excellent model if you want soemthing simpler.
Feb 22, 2011 | Pentax K1000 35mm SLR Camera
I had taken a whole roll of pictures with my Pentax K1000 but when I got my film back, my developer told me there was nothing on it. When I took the pictures I did not change the shutter speed or move...
if that nickel sized battery was dead you would not hear the shutter work. i have one of those oldies and they do take great pictures when they work right.lens cap isnt on it right??
Aug 07, 2017 | Pentax K1000 35mm SLR Camera
I have Vista and need a driver for Pentax, Optio S digital camera. I have a USB cord for the camera but not the disk. When I turn on the camera all I get is a black screen with the letter and number A90. I...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Aug 21, 2010 | Pentax Optio 33L Digital Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
My shutter is sticking; half of the picture is black
This is not a user repairable problem.
You need to take it for a professional repair. The good thing is that this is an all mechanical SLR and was designed so that repairs are usually straightforward. Spares are no longer available, but so many of these cameras were sold and are still in use today that many repairers have a few scrap examples which they can cannibalise when needed.
Given that you can buy a perfectly good used K1000 at online auction sites for between £30-£40 it may not seem like an economical repair, but newly serviced ones with a guarantee sell for over £100 so it's definitely worth it for such a superb classic SLR.
Jul 09, 2009 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Mar 21, 2009 | Pentax K1000 35mm SLR Camera
Black bar on rt. side of photos.
elockepens
is this black bar on all the time or only when using flash? if only when using flash then your shutter speed is to high. for flash on the K1000 the shutter speed must be 1/60th sec. or slower.
if the black bar is there all the time then the shutter must be adjusted, cleaned and lubed.take or send your K1000 to a camera repair shop for an estimate first as there are no new part available,
Feb 02, 2009 | Pentax K1000 35mm SLR Camera
Lens damaged camera dropped camera body damaged pentax k1000
Mar 15, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
147 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
