Question about Standard Horizon Cp180 Chartplotter
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
One of the male pins on the unit for the antenna is broken, the unit will not get gps signal with this single pin broke.
    Problem Solver:
  • 7 Answers
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Posted on Feb 21, 2012
Testimonial: "Hi John, Yes the broken pin is on the unit. I will have to take the unit to the electronics repair man as I am not that familiar with soldering. I was hoping for the "user replaceable plug", but knew that would be a long shot. thank you very much for your help. "
I have a Schumacher WM-10000A speedcharger and the ground pin on the male plug (built into the unit) has broken off. I need a replacement male plug for this unit. It has been a great charger and I cannot...
Too easy...go to any of the DIY stores, Lowes or the Depot, or your local hardware and pick up a male end for the cord. It's an easy installation, will take you MAYBE 10 minutes.
Jan 27, 2011 | Schumacher & Fast Charge Starter Charger
I have a set of Harmon Kardan Soundsticks II needing a simple but confounding repair. One of the small pins (#5 I would say as you go over and around the arc of pins) of the satellite speaker connectors...
MiniDIN-4 Connector Pinout. Looking at the male connector from the rear (solder side) Pin 1 = White Pin 2 = Bare Wire Pin 3 = Light Grey Pin 4 = Dark Grey Outer case Ground = Clear
Jan 02, 2011 | Harman Kardon SoundSticks II Computer...
How to identify power supply chips in mother board
Power supply chips will be usually 24 pins or 20 pins. It will be a male kind of pins with white plastic surrounded by it. The power will come from the SMPS which will fixed on the top of the CPU in the back side. The power supply to the processor is again a male pin which is of 4 pins. this will be located very near to the processor itself.
Aug 03, 2010 | Compaq Computers & Internet
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
AC post broke
Dear Bruce;
Unfortunately the computer industry is a little bit better than the automotive industry. I thank God that I am not a automobile mechanic and I have seen some very smart and well accomplished mechanics. The mother board is not made to be repaired for the desktops and more so for the Laptops. Now, you seem to be a reasonable man and my reasonable thinking is that you throw nothing away as long as you can keep them working. How do you know if the next new equipment you buy will not be a lemon. So, you have examined the male pin for recharging, you already have found that the damage is not that much, it will not fall out within some time. We are lucky that the voltage that point is not that much. I would say give another visual and if you are satisfied, fix it and see how much life you can get out of it. Always keep an active back up of the unit, just in case, even though data loss happens when the program is in the RAM memories. Fix it up and be proud of your accomplishment. If there are funds available, figure a time that it would be wise to have a reserve. Run your computer until the battery burns up or the "wheels fall off". May the Lord bless you! My name is Constantin (arzconst is my internal nickname with the Fixya.com).
Jun 19, 2009 | Computers & Internet
Tom Tom 1 Not charging.
I have had the same problem.
after carefully dismantling the unit I resoldered the connections to the power plug.( using a fine tipped soldering iron) I did this on both sides of the pcb.
Although the joints did not look to bad after re soldering and reassembly the unit has performed faultlesly ever since.
As you have to disconnect some sockets and remove pcb,s to do the job properly its best done by someone competent in this sort of work.
One thing to note that caught me out, make sure the lead from the internal antenna is connected as you put the unit back together
Nov 07, 2008 | Tomtom ONE GPS Receiver
Thanks for the input.
hi, Check the photo below to see if your plastic lugs are in good condition . If they look OK then it is possible you have a bad contact to the pins or maybe even a bent pin. be careful though as the contacts are very easily damaged if you go prodding around.
Sep 21, 2008 | Tomtom GO 910
Pin in back of receiver broke off
If you can put your hands on another unit for parts, you can open it and replace your damaged pin with one from the unit for parts. It takes a little time and care but you can do it.
Mar 17, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirius sportster and dock
If you bought it within a year, it should be under OEM warranty. If it has been longer than a year, but shorter than two years, and you bought it with Visa, MC, or American Express, you probably qualify for extended warranty protection from your credit card company.
Jan 08, 2008 | Rio SIRIUS Sportster Replay Receiver...
Standard Horizon Cp180 Chartplotter Logo
122 people viewed this question
Top Standard Horizon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
