Question about Tools & Hardware - Others
Need to know trigger assembly for senco staple gun sks gb0199-1
Trigger asembly
SOURCE: ASSEMBLY
I just had to repair one of these guns for work. It's a bit tricky, seeing as you are dealing with springs and such...but it can be done. Take your time ...don't set the springs until you have things set in place and lined up. Make sure the pins are in place. Set the flat spring first (it is the toughest) while the handle is depressed all the way in. Gently open the handle and then set the torsion spring. Take your time here...springs are set and they could make all the pieces fly out if you don't quickly get the other half put on it. Hope this helps.8d59edb.jpg
Posted on Feb 13, 2008
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
I have a senco stapler how do I change it so I do t have to squeeze trigger every time. I want to hold trigger down and just press to underlayment. Can't figure out how to change it.
Hi Jack,
Depending on the model number you have, Just replace the trigger with a SEQUENTAL trigger. This is a genuine SENCO part and is completely complient with all Health & Safety law. if you need a parts chart, email me at the website below. We are SENCO dealers for over 30 years in the UK Leigh Co Limited
Jan 19, 2015 | Senco Tools & Hardware - Others
My senco 1/4" crown air stapler would not drive a staple & now leaks air constantly
It sounds like you have broken or damaged o-rings inside the gun and the only repair is to replace them. Senco does make kits to rebuild most of their guns. Go to http://www.senco.com/ and click on 'Parts Charts' at the top of the page then find your model. The PARTS GUIDE will list a rebuild kit if one is available. The part number will start with YK followed by four numbers. If there isn't a rebuild kit available for your gun, you'll have to order each o-ring seperately. All o-ring part numbers start with LB.
Feb 16, 2012 | Tools & Hardware - Others
I need to replace the rubber tips on my senco sfn1 nailer and my senco sks stapler. Do you know where I can buy them?
Look for a Senco dealer or tool supply place in the yellow pages or go to senco . com and enter your zip code for your nearest dealer. I found replacements at Hughs tool supply.
Jun 12, 2011 | Senco SKS 18 Gauge Stapler
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Do i need to buy piston driver assembly or can i by just the driver blade
These new Senco FinishPro tools are chinese made and unlike the old US made tools, you need to buy what's termed a 'piston driver unit'. It should be fairly cheap though, compared to old Senco parts.
Jan 17, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
I can't figure out how my synco sfn1 trigger assembles!
Go to www.senco.com, click on the 'Nailers, Staplers and Collated Screwdrivers' picture and it will take you to an information page. Your gun is under the discontinued models drop down menu. Select your gun and hit GO any you'll be on a page with a Parts Chart. That should give you a better idea of how it's assembled.
Aug 23, 2010 | Tools & Hardware - Others
I have some air nailers and staplers that have some leaks and aren't working properly. I would like to try rebuilding them, they are bostitch, paslode, and senco. I have found the rebuild kits for trigger...
The kits for the senco guns, have all the o-rings and seals needed to stop most leaks, no hard parts. You have to replace all of them, no oil is needed, but it needs to be clean, some have little tubes of grease for the o-rings. I'm sure the other guns are the same way. Some of them will give you a fit. I had a senco sfn1, totally rebuilt, still leaked, tried it again, still leaked, called senco, they said send it to us, they fixed it for free, but never said what the problem was. Some times the triggers go and you end up building the whole gun for nothing, and the trigger still leaks, they are the toughest to spot. I have seen a lot of complaints about paslode. We tried them all in our shop, and the senco was/is the best, So we fazed out all the other guns and kept the senco, so all the nails were from 1 dealer, all the parts, we weren't looking all over town for a box of staples.
Feb 23, 2010 | Stanley Air Tools & Compressors
Tools & Hardware - Others Logo
48 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
