Question about Car Audio & Video
I have a Clarion CMD4 in my boat. The unit no longer will take in any CD's . They will only go in 1/4 of the way and stop. If you force them in, which you should'nt have to, they won't play nor will they come out on their own. To make matters worse, the sirus radio quit recieving signals, and the unit only will recieve am or fm signals. The unit was made in 2005, but probably only has maybe a total of 20 to 30 hrs. of use on it . Is this common with this model, and is this not a good manufacture brand name. Is it worth trying to repair, or should it be replaced?
SOURCE: sirus radio
I had to replace my Sportster because it was overheating and caused it to loose signal.
Posted on Jul 13, 2007
  • 6 Answers
SOURCE: sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Posted on Feb 19, 2008
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
sTatiC00000L
  • 8 Answers
SOURCE: XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Posted on Sep 08, 2008
cadman000
  • 607 Answers
SOURCE: !994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Posted on Apr 06, 2009
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
One of my customers has a CMD6 with SIR-CL3 Sirius receiver. When powered up the unit displays "SIRIUS NO TUNER" and then shuts off, powers itself up again, repeats display message then shuts...
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Feb 08, 2011 | Clarion CMD6
I installed the unit in my boat and it functioned properly until today. I get nothing when I turn it on. the fuse is good. any way to check this out
if you have 12v at fuse and the ground is hooked up then the unit died. or if you have a removabe face its not contacting
Jul 31, 2009 | Clarion M275 CD Player
Volume issues with clarion M309 installed on a boat
Hello jcox7704,
Your head unit is 50 watts X 4 channel maximum power and 21 watts RMS so it's possible that all you need is more power to the speakers. But even 21 watts RMS should be enough for normal speakers. Before investing in an amp, I'd check the speakers and their wiring. Measure the impedance (resistance) at the head unit side to see if they match up.
Hope this helps.
Jul 02, 2009 | Clarion M475 CD Player
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Jul 01, 2009 | Clarion DXZ545MP CD Player
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
