Question about D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps Networking Switch
Connecting xbox live to my d link 1005d
My teenage sons wanted me to buy a new router as i have fine internet speed with optus cable, but the xbox and computer were lagging to much. I went and brought a d - link dgs 10005d router and the xbox live is not connecting to ip address. Can i get help with this as i am all new to this
    Problem Solver:
  • 10 Answers
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Posted on Nov 28, 2008
I have d-link des 1005d and i have ps3 and pc . i have Motorola modem sb5101 .. i want get connected both ps3 and pc at same time will u plz tell me how i will set up tks
You should use a router instead of a switch...however if you still want to use the switch, request your service provider to provide two ip addresses, instead of regularly just one...but you mostly like need to pay monthly the extra ip address...alternatively ask your service provider to upgrade your cable modem to cable modem with router capability, ...
Apr 12, 2011 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Running two xbox live 360
Hello there.
A router shares your internet connection with local computers and devices on your local area network. Microsoft's xbox live requires a connection to your IP address on a certain port. This will be a problem when using 2 xboxes so what you would need to do is contact your Internet Service Provider, explain that you are using a router and require an additional Static IP Address.
Once they provide you the details for this, you can manually set up one of the xboxes with the static details your isp has given you.
This should stop the 2 xbox conflicting over connecting to the internet, as they will be running on seperate ip addresses.
Hope this helps.
May 19, 2008 | Microsoft Xbox 360 Console
We recently got an Arris TM722 modem and a netgear wireless-N 150 router WNR 1000 after getting a new ISP. My problem is that every time I turn on my xbox to connect to xbox live, my xbox doesn't connect...
Recheck your settings on the xbox.
If using wifi on the xbox, you'll have to setup a new connection to the new router.
If the xbox is wired via cable to the router, you may need to add a router password or other settings .
Jun 21, 2017 | Computers & Internet
My home network is such that I have a DLink Gigabit switch right behind my DSL router to dispatch network connections through the home. I already connected several devices that work without problem. One...
Check the network settings of your pc in network and sharing, adapter settings , right click local area connection and press properties, click IPv4 and look at its properties. Ensure ip and DNS are bother set to auto.
press start, type cmd right click the grey chalk board press run as administrator. Type ipconfig /release then type ipconfig /renew
also try a different port/cable if it is a gigabit switch an orange light means it is running below the speed. I.e. 10/100 if it is working correctly the lights should be green.
Apr 06, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Hello, Got a D-Link 1005D 5x100 Im having 2 computeres atm, but i cna only get one to work. When i plug the internet cables from the computers to the D-link router, only one can work, please...
Your D-Link is a "switch", not a "router".
So, every computer that you connect will require a _UNIQUE_ IP-address.
However, your account with your Internet Service Provider is only granting you *ONE* IP-address.
Upgrade your account to pay a few dollars more per month, to get additional IP-address(es).
Buy a D-Link Router, for under $50, and connect both computers to the 'LAN' ports,
and connect the 'WAN' port to your cable-modem (or DSL-modem).
Dec 08, 2010 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Dynex10/100m router not connecting to internet
1. check the router to see if you have a firmware update
2. check cables ( make sure you don't have a crossover cable.
3. check firewall in router and the PC OS ( operating system)environment.
4. check the setup for the XBOX
Apr 18, 2010 | Dynex 4-Port Ethernet Broadband Router...
I have an Apple Mac connected to Netgear router. Partner has Del laptop which she wants connected via my router. Bought D Link 1005D switch but don't know how to connect both of us thru it. Do I need set...
What type of Netgear Router you are using?
If you have more than one ethernet ports to your Netgear Router, then connect your switch with a patch cable to the Router. Switch on it and check.
So that can share the resourses.
Dec 28, 2009 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Tcp ports
it depends on the type of internet service you have if it is cable internet most cable modems can act as a gateway for conecting multiple computers but the cable company needs to activate that feature on the modem.
Jan 03, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps Networking Switch Logo
663 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
