Question about Thule 686 Atlantis 1600 Cartop Carriers
Lock is jammed
Cannot get carrier to lock
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Spray some WD-40 into the keyhole in the lock and wait a few minutes for that to set in. Then try to turn it again. If that doesn't work, the lock cylinder may not be inserted completely. Use the removal specific "key" that comes with Thule locks to pull the lock cylinder out, then reinsert the cylinder completely before removing the removal "key".
Posted on Jul 10, 2014
Industrial sewing machine has jammed, the wheel will not turn
Hello Christine, I think you do have a thread stuck between the rotary hook and the bobbin case carrier. Remove the bobbin case and bobbin. You will need to remove two small slotted head screws and remove the half circle locking ring that holds the bobbin case carrier in place. Try to wiggle the bobbin case carrier one way and than the other until it comes out of the rotary hook assembly. Don't pry too hard or you might damage the carrier and/or rotary hook assembly. Once removed, I think you will find the thread that is causing the lock up situation . Before reassembling, place a drop of oil on the bearing surfaces between the carrier and rotary hook assembly and also between the locking ring and the carrier.
Mar 07, 2014 | Sewing Machines
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Carriage lock on adler typewriter
Turn the T/W off, slide the carrier to the R., look for debris in the carrier area. Spray some WD40 on the silver shaft that the carrier slides on.
Move the carrier back and forth to be sure tghere isn't a bind or hitting something.
DickyO
Aug 29, 2012 | Royal ADLER Satellite 40 Typewriter TA...
I Got a dell printer and i don't know what to do and in the printer it says Clear Carrier Jam
Turn the printer on.
Lift the lid to expose the print-head mechanism.
The "carrier" is that part of the mechanism that moves the print-head across its range.
Something is physically blocking, or "jamming", that carrier.
Feb 25, 2011 | Dell V305 All-In-One InkJet Printer
My processor is jam the carrier will not return
Some models have a carrier lock. Look around the sides of the carrier for a blue lever that may be engaged.
Nov 10, 2010 | Smith Corona Wordsmith 100 Typewriter
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Scanning
sounds like the carrier might be jammed, lift the lid and plug the scanner in, see if the carrier assembly moves ?
Feb 27, 2008 | Canon CanoScan D1250U2 Flatbed Scanner
Thule 686 Atlantis 1600 Cartop Carriers Logo
682 people viewed this question
Top Thule Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
