Question about Peavey Music
Peavey SP 118P speaker leads...blue and yellow? which one goes where on the speaker?
If only they were black and white or black and red....nope blue and yellow. So which lead goes red on the speaker here? i didnt take the darn thing apart, just trying to clean up someone elses mess
    Genius:
  • 1,212 Answers
Blue should go to red. I assume they used an Asian standard. Rough way to remember- sky blue, return brown/ground is green yellow- same potential as brown. yellow somewhere in between.
However reversed leads are not going to be noticed on the speakers of a single amp/speaker. Or if a multi speaker setup in a cabinet as long as all are mated with the same polarity.
It just translates to the direction a speaker cone is moving in relation to the magnet when the polarity of the sine wave peak is positive.
In a stereophonic setup- many can hear the difference an out of phase speaker can make, in a monophonic setup- no one is going to hear the difference. And on a stage setup, unless the speakers are all attached to the same source, they are all moving independently.
Posted on Feb 18, 2012
Sp 3g crossover wiring color code
Horn is red +, black -, mid is white +, blue-, lows are yellow+, blue-. If you look at the crossover board, you'll see the treminals are labeled what goes to where.
Apr 21, 2014 | Peavey Music
In Peavey cabinets, the woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the mid the remaining two wires would be the lighter color + and the darker color -
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
Feb 03, 2012 | Peavey SP2 PA Passive Speaker
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
Jan 12, 2011 | Behringer B415dsp Eurolive 600watt 15 PA...
The blue and red cable came loose on my peavey pr 15 neo 2 way speaker
Put the red on the + side and the blkue on the - side. SECURE the wires so that their weight does not pull them loose again. You can pop amps when speakers come loose...
Jan 02, 2011 | Peavey PR15 400w PA Speakers
Peavey Rage 158 guitar amp
I don't believe there is a power "outlet" on this, only an "inlet".
Usually the inlet will have a lead, often green, that goes to the chassis.
There will usually be two other wires, often black and white that connect to the other two pins.
From the back of the connector, with the center pin tied to the grenn wire of the triangle lower, the pin to the right should be the white and the pin to the left is the black wire
Jul 24, 2010 | Peavey Kb2 1x10' Keyboard Amplifier
Changing the output Jack on 1985 Peavey Dyna Bass
If this has active circuitry, one of the wires is the cutoff for the power supply from the battery. The other two are black for ground and either white or red for signal.
Mar 13, 2009 | Peavey Music
Music Logo
262 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
