Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Model ET18GK why is water getting into the refrigerator
Mine does not have a ice maker
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Posted on Apr 27, 2009
  • 77 Answers
SOURCE: whirlpool et18gk freezer working frige not
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop.
What you probably have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $40-$80 for the fan motor then labor on top of that. The fan part number is 2315539.You should be able to order the part anywhere that sells appliance parts by that number with no problem at all.
Posted on Jun 02, 2010
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
No ice or water from Samsung side by side refrigerator, it Samsung ice maker was making a whooshing sound and now we get no water or ice
Take a close look at it, mine sometines freezes up because one of the kids left the door ajar. I fix mine with a hair dryer.. DO NOT use a knife or any kind of sharp item to lossen the cubes that might be frozen into the ice maker.
Mar 15, 2015 | Samsung Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Gss20I eph ice maker ?? If I turn the switch of
I am almost sure the model ice maker for your refrigerator is Click Here=> WR30X10093 and the model number for your refrigerator is GSS20IEPHWW or SS for Stainless. It sounds as if a bad connection on the ice fill arm. The truth is they are electronic and made in China along with most of the parts on your GE. I replaced mine that was the mechanical type with this same model number WR30X10093 and the mechanical lasted 15 years. If you manually can make it work one time and fills properly but after one cycle yet turns itself off my focus is on the ice maker. If you want to check OHM's to the dual water control valves they should both be about the same. Applying 120 volts to each side of the coils being water dispenser side and ice maker side will or should open them. But you just said that moving the arm that it will fill one time so I am back to the ice maker again. If water control valve for ice maker side did not work you would not be able to do that. Sea Breeze
May 20, 2010 | GE GSS20IEP Side by Side Refrigerator
I have a model GD5PHA whirlpool refrigerator, no ice
the ice maker control the water timing.
if you have voltmeter you can check it on the water valve that go to the ice maker. but you can also disconnect the water from the valve and see if water are coming out.
99% its the ice maker that go bad.
Jan 19, 2010 | Refrigerators
Ice in ice maker compartment smells
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Jan 01, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Ice maker
I am having the same problem with mine.
Jul 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
26 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
