Question about Frigidaire FEQ1442ES Electric Dryer
Feq1442es1 error codes - Frigidaire FEQ1442ES Electric Dryer
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
How do I get the drum out of my Frigidaire dryer model number FEQ1442ES1
Hello friend, I appreciate your post!
From my understanding you want to remove the drum out of your Frigidaire dryer. These complex parts do require precision and patience, therefore when replacing the exchange such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Sep 28, 2014 | Frigidaire Dryers
FEQ1442ES1 works but no heat
Instructions
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Jan 09, 2013 | Dryers
FRIGIDAIRE MODEL FEQ1442ES1 LIGHTS FLASH THEN DRYER SHUTS OFF
Hi - From what you have described the unit could possibly have a communication problem with the control board. However, if the unit is producing heat but will not complete cycle please confirmed that the door is closing properly. If it is not, the unit could possibly have a defective door switch or cord/wiring. Either, or, could be faulty at this time. I would suggest contacting a professional to move forward accurately since this is not a typical DIY job.
Oct 13, 2012 | Frigidaire FEQ1442ES Electric Dryer
Control panel not working
If you have power going into the control but it does not illuminate or respond the control will need to be replaced. Here is a link that should help http://appliancehelponline.com/dryerconsole.html These boards are very sensitive to power surges and are not repairable, they must be replaced.
Jul 27, 2010 | Frigidaire FEQ332E Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
155 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
