Question about HP Pavilion dv9000z Notebook
Screen wont light up
Power is on but the screen wont light up and every thing else seems to be ok
  • HP Master
  • 5,660 Answers
Wafy_m, the problem can be attributed to the graphics chipset, is lifting off of the motherboard.
The mounting has loosened.
This is because the cooling system for the graphics chipset, is inadequate.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset is the GPU,
http://en.wikipedia.org/wiki/GPU
The mounting of the GPU to the motherboard, is done with a BGA surface mount,
http://en.wikipedia.org/wiki/Ball_grid_array
To explain a BGA surface mount, compare to an older Intel Pentium 4 processor, that uses a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The Processor has contact pins on the bottom. 478 of 'em.
The Socket 478 processor socket has matching socket holes.
With a BGA surface mount there are no contact pins, nor socket holes.
In place of the contact pins there are Solder Balls.
In place of the socket holes there are Copper Pads.
(Which have a gold plating on them)
The graphics chipset is set into place over the motherboard, with it's Solder Balls lining up on the motherboard's matching Copper Pads.
Heat is then applied at a specific temperature, and length of time.
The Solder Balls melt, which solders the graphics chipset to the Copper Pads.
(Which in turn solders the graphics chipset to the motherboard)
With the inadequate cooling for the graphics chipset, after time the solder connections will begin to partially melt.
This leads to a poor contact of the graphics chipset to the motherboard, and the problem you are having.
As previously stated the cooling system for the graphics chipset, is inadequate.
Cooling System:
The cooling system consists of a Cooling Tube, Heatsink, and Fan Assembly.
The Cooling Tube is a slightly flattened copper tube, filled with Nitrogen, and sealed on both ends.
Towards one end of the tube is an aluminum plate. This plate sits on top of the Processor. Has four screws through it. Removing these screws removes the cooling system assembly.
Coming up the tube a little bit, is another aluminum plate. This one is smaller, and sits on top of the graphics chipset.
Connected at the opposite end is the Heatsink.
The Heatsink is a small thin piece of metal, with Tall, Thin, fins protruding from it.
Next to the Heatsink is the Fan Assembly.
The Fan Assembly, is a Fan inside of a cage, or shroud.
Draws air up from the bottom of the laptop, and pushes it through the Heatsink's fins, and out the side of the laptop.
Heat from the graphics chipset, and the Processor, are absorbed by their metal plates.
The Cooling Tube absorbs heat from the two aluminum metal plates.
The Cooling Tube transfers the heat along up to the Heatsink.
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Airflow from the Fan Assembly, helps to carry heat away from the fins of the Heatsink.
The surface area of the metal plate on top of the graphics chipset, is too small. It is inadequate in surface area size.
The one on the Processor is barely adequate.
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=relmfu
The above is posted for reference. Pause the video at 7:43 to see the cooling system I described above.
1) Black Fan Assembly to the upper left.
2) To the immediate left side of the Fan Assembly is the Heatsink.
Black in color, slightly rounded outside edge, goes along the full length of the left side of the Fan Assembly. Hard to discern the fins.
3) The aluminum X shaped piece with 4 black screws in it, on the copper Cooling Tube, is the metal plate for the Processor.
4) Coming up the copper Cooling Tube towards the Fan Assembly, is the second aluminum metal plate. It is shaped sort of like an S, with flat ends. This plate sits on top of the graphics chipset.
Solution?
Properly remelt the solder connections of the graphics chipset, to the copper pads.
Add surface area to the Processor's metal plate, and the graphics chipset's metal plate.
PROPER method is to use a BGA Rework Machine. Performed by a shop who has one.
ANY other method may is less than. The procedure may last a week, a month, or maybe longer.
There was a recall on this series of Notebook PC.
It is over,
http://www.nvidiasettlement.com/index.html
[ No, replacing the motherboard does NOT cure the problem ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 18, 2012
  • joecoolvette
    joecoolvette Feb 18, 2012
    EDIT:
    "ANY other method may is less than."
    Should be, "ANY other method is less than."
Rockola download jukebox lights and screen do not turn on, but "insides" seem to be running ok. Screen says no video connection, then goes blank. Video cables are ok.
The lights inside most likely indicate it has power and is waiting for power button to be pressed. Could be as simple as power switch is failing.
Feb 23, 2015 | Computers & Internet
connect with external monitor or tv.
if works ok you have problem with display or the cable that connects the display with motherboard. If your model is too old maybe you have problem with inverter.
Feb 17, 2012 | HP Pavilion Computers & Internet
DDW1802W ran fine yesterday. Panel light os, no start. Door seems to latch okay. It's not an overflow switch issue. No burnt smell.
dishwasher wont turn on. power is ok. when you turn the dial with the power switch on it clicks motor turn on pumps do not turn on wont fill or empty power light does nnot light up latch seems to be fastening proper is there a reset switch
Apr 09, 2011 | Danby 17 in. DDW1802W Designer Series...
My dell inspiron 1525 wont switch on, no lights or sound at all please help!
The first thing to try is a different AC adapter. About half of all no power failures are the AC adapter no longer sends power to the system. You can also use a multimeter to check the DC output of the adapter (About 20VDC) If the AC adapter is putting out power or a known good adapter doesn't make any difference, then try reseating the LCD hinge cover cable connection. If still no power and especially if the power jack seems to be damaged, then a motherboard replacement or adapter jack replacement is required (Roughly $100 either way)
Nov 13, 2009 | Dell Computers & Internet
Philips 42pf7621d/10 dead
One of the circuit boards should be replaced inside, probably the power supply, the good thing is that screen is ok and it's a most expansive part, you can take it to the local repair shop for diagnostic and repair.
Oct 10, 2009 | Philips Televison & Video
Black screen
have you tried checking the day time power saving settings to see if they have been incorrectly set
Aug 29, 2009 | Sony VAIO PCG-K23 Notebook
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Ps2 slim line
if the laser is moved to the middle of the area and when you first turn it on it doesn't go back to starting possession's then some thing is wrong with the motor drive more than not it's likely you have a crack in the board.
Jan 03, 2008 | Sony PlayStation 2 Slimline Console
My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Apr 23, 2007 | SanDisk Sansa e250 MP3 Player
HP Pavilion dv9000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
