How to repair a gateway ml6714 notebook, the power plug in shorts when power coord is plugged in
    Genius:
  • 1,250 Answers
IF YOU ARE NOT SOUND ON TECHNICAL GROUND ITS BETTER TO BE DONE BY SOME TECHNICIAN
Posted on Oct 26, 2008
Coord is fine tried many differant outlets, bu as soon as i plug it in the circuit braker trips.Any help about where the short is?
65 AMPS? That's drawing a LOT of power.
Is it tripping the breaker even before you pull the trigger?
If yes, I would use a continuity meter to start checking the various components. In particular, see if the switch is stuck in the ON position.
Unless you are experienced in tracking and performing electrical maintenance problem solving, this may be a situation best left to a repair shop.
Cheers
Mar 13, 2016 | Dewalt DW303 Heavy Duty 65 Amp...
Power port for gateway MT6840
First easy check is to stick a toothpick into the jack to see if the middle pin is loose. If it's not loose, try another power adapter to check just incase. If you dont have one ask around to borrow a universal one. Dont jiggle and wiggle the plug with the power plugged in if it is loose because i've seen shorts happen.
usually plugs are mounted onto the mainboard. To get to the main board, you'd have to take apart everything because everything attatches to the main board. The case, keyboard, heatsinks, speakers, and so on must come off before you'll be able to see the power jack. With parts and labor, it comes close to a new laptop.
Jul 29, 2009 | Gateway MT6840 Notebook
WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Jul 04, 2009 | Western Digital My Book Essential Edition...
Will not power up for more than 1 second. Without battery installed, will not power up at all
Sounds like battery is dead. Have you been having problems with power cord? When you plug in power cord with battery installed you should see a charging light. Maybe wiggle coord and see if you get some power. Toshiba, In my opinion is a great computer, but they do have a poorly designed power plug. They are forever being broken from the boards. I hope this helps and if it is a bad power socket, you can get them from Ebay for about $5. Good luck and have good day.
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
you can take the laptop to a laptop shop & have them resolder the power plug to the mother board or purchase a new motherboard.
Jan 16, 2009 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
