Question about PNY 4GB Micro Attache USB 2.0 Flash Drive
Computer keeps telling me to format usb stick if i do i lose all my data
  • PNY Master
  • 27,725 Answers
Click start control panel administration tools computer management disc management right click on your drive select properties tools check now scan for and attempt to recovery bad sectors and
automatically fix any file system errors tick in both boxes or tick one box then wait until it has finished then return and tick in the other box
i have found the best results ticking the first box then returning after chkdsk has finished automatically fixing files
you should have no input while chkdsk is running any input might further damage your hard drive
hope this helps you
Posted on Feb 19, 2012
Kingston dt101g2
if u can format your device format as fat32....before format keep your data...
Jan 02, 2014 | Audio Players & Recorders
How to recover data of Memory stick without formatting?
As your description, I think your memory stick is error which may cause by virus attack or partition corrupted. It won't hurt to try to plug the stick to another computer and see whether this case happan again,if it does, besides you can use the chdsk tool in windows to fix the error, However if you can not fix it ,you should recover the data from memory stick firstly, know more here: Memory Stick Recovery
Mar 26, 2013 | Sony 2GB Memory Stick PRO Duo Memory Card
Computer says i have to format usb stick but if i do i lose my files
try application to rcover your files such as AnyReader or diskdigger
they are v good then format you flash
Feb 17, 2012 | PNY 4GB Micro Attache USB 2.0 Flash Drive
My usb memory stick suddenly stopped opening and wants to format. Have I lost the data on it?
Hi there.
If you will format the USB stick, yes you will lose all the data in it.
Thank you for your question.
May 27, 2011 | Microsoft Windows XP Home Edition
My memory stick says it needs to be formatted, but i cant lose the work. I have downloaded three differant types of file re-storers. none of them have even picked up that my memory stick is there.HELP!!!...
you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Jan 28, 2011 | Computers & Internet
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
My pc havet a drive for my flash memory
If you want to format to remove all the data from your flash drive and wipe it clean you do not need a program as you can do it through windows.
Step 1 - Plug in your flash drive to a working usb port Step 2 - Click on start and then click My Computer. Step 3 - Find your memory stick. In most cases drive C is your hard drive and drive D is your disc drive. This means that your memory stick is most likely drive E. It is a removable storage device and not your hard drive. This is very important because you don't want to format your hard drive. Step 4 - Back up any data you want to keep from your flash drive. When you are done with the formatting everything will have been removed from it. Drag the files you want to keep from your memory stick onto a folder on your computer. Step 5 - In your My Computer folder right click on your flash drive icon and click format.
Mar 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Computer is not reading USB hard drive
Check out this blog post by these flash drive professionals:
http://www.flashdrivepros.com/_blog/USB_Flash_Drive_Data_Recovery_Blog/post/Help!_Windows_No_Longer_Recognizes_My_Flash_Drive!/
...and if that doesn't help, you can always order their cheap service. Its great that they have a guarantee, that if they can't recover your files for you, then they'll give you a full REFUND.
Feb 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My K770i says to reformat but i do not wanna lose my pics
Cellphones have a nasty habit of being very picky about how their memory cards are formatted (especially verizon phones). You will need to plug it into a computer and remove everything off of it. Most multi-media card readers will accept this format of flash media. If you still wish to use it in your phone afterwards you'll have to let it format it.
Mar 25, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Problem with corrupted files
Dont panic... Just insert the memory stick in to a card reader and donot try to open it. but make sure that your memory stick gets detected.Then you can use any of the file recovery softwares to recover the photographs with out formating.I generally use the free app "PC file recovery". In case your memory stick is not detected in the first place, then There is no other option other than formatting. But the recovery software can recover 90% of the photos even after formatting.
If this doesnt work, post back. I will explain in more detail.
Nov 09, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
PNY 4GB Micro Attache USB 2.0 Flash Drive Logo
166 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
