Question about Logitech QuickCam Fusion Webcam
Blurry and dark picture
My Logitech Fusion worked perfectly with good light, color and picture resolution. Recently, I had to replace my monitor, and now I only get low resolution and very dark picture. Other than buying a new monitor, I made no changes to the cam or settings, so I'm stumped. My system is Win XP and I use MSN as well as other flashplayer 9 based video chatrooms.
  • 2 more comments
  • luke1812 Oct 26, 2008
    Thank you for the rapid response. I made no changes to the video drivers, I just plugged in the new monitor. Overall picture in monitor is brighter, cam picture darker... drat...
  • DoubleO Jan 07, 2009
    Please I bought a Logitech Fusion Webcam and the Pictures are so Dark. I followed all the instructions but to no avail. Once in a while it adjusts do being bright but goes dark again. i am really devastated because I really looked forward to buying it.
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmm..well..that is most assuredly a driver compatibility issue..i recommend going to www.logitech.com and simply re installing the drivers..can not hurt..
    hmmm..this is quite interesting..perhaps there is a compatibility issue with the video drivers? logitech.com
    is most likely place to find those..
The overall picture quality with the new monitor is awsome. It only the little window generated by the webcam that I saw a sudden drop in quality. I'll try re-installing the cam drivers and also look at whatever it is on that disk that came with the new monitor. I thought as long as the overall picture was good, there was no need to tweek with the monitor settings....
Posted on Oct 27, 2008
Here's a thought.... When I got the new monitor, all I did was plug it onto the cords that were left where the old one was. I went from a Viewsonic to a Samsung. There was a driver disk of some sort come with the new monitor, but I didnt think it was important. Is there any reason to belive that failure to install whatever is on that disk could be responsible for the sudden drop in my cam's performance?
    President:
  • 2,712 Answers
Is the issue occuring only with the webcam, or is the picture quality of the new monitor bad in general? I would suggest checking the monitor properties via control panel. You can also try reinstalling the webcam drivers. Try that first and let me know how it goes..
Posted on Oct 26, 2008
Toshiba 50H81 very dark, blurry picture on all inputs.
check if the problem looks zig zag looking or it its not present in the PIP window. If so this may be an issue with the hypermodule - you can google TV repair Kits to find parts.
Mar 27, 2012 | Toshiba 50H81 50" Rear Projection...
Everytime i put a picture for the background on the desktop it doesnt come out clear its all fuzzy/blurry anyone know what's happenin?
It's because your resolution(size) of your desktop is larger than the resolution(size) of the picture. If for example you are running a resolution of 1280x1024 then a picture with the dimentions of 1280x1024 would fit perfectly and not be stretched. See my tip on setting the desktop background here for further details: http://www.fixya.com/support/r6775332-change_desktop_background_image
If you want a smaller image to be centered and not stretched then right click on your desktop and go to Properties. Then click on the Desktop tab. To the middle right there is a heading that says Position. Click the little selection to Center. This will center a smaller image instead of making it all blurry and stretched.
May 27, 2011 | HP w1907 LCD Monitor
The resolution is very dark and not clear
You should first try improving the lighting on your face, and be sure to avoid all light from behind you (close a curtain if necessary). Good lighting improves both color and resolution. The article How To Improve Your Webcam Video Quality provides lots of other free tips.
Apr 16, 2010 | Logitech QuickCam Express Web Camera
I RECENTLY STARTED USING BENQ MONITOR & NOW I HAVE IRRITATION ON MY EYES. WILL THERE BE ANY RADIATION FROM BENQ MONITORS
There's practically no radiation from LCD monitors, especially compared to older CRT monitors, which radiated several sorts of electromagnetic waves.
Is the picture on your monitor crisp, with good focus? If the letters and shapes are blurry, it may mean that you are using a different screen resolution than the native resolution of your LCD.
If your monitor type is FP731, then it's native resolution is 1280x1024 and this is what should be set in the Display Properties under Settings tab (in Windows). If it's a different model, you can search for it's specs on the web to see what is it's native (a.k.a. optimum) resolution.
Please rate and possibly leave a testimonial if helped.
Jan 06, 2010 | BenQ FP731 17" LCD Monitor
QuickCam fusion webcam doesn't take pics of a higer resolution than 960x720
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 24, 2008 | Logitech QuickCam Fusion 961403-0403...
Color Resolution
Sounds like a piture tube or internal video driver in your monitor. You probably lost the green channel. If the monitor is dated I would replace it.
Aug 31, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor problem....(blurry image and red flickking)
the only real soluton is to replace this monitor sounds like the red cathode is shorting out (basicly piture tube is going out.
Jan 30, 2008 | Computers & Internet
Logitech QuickCam Fusion Webcam Logo
160 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
