Question about Toshiba E-STUDIO 550 Copier
I have a Toshiba e-studio 550 that gave me an error code of CD3. I searched for a resolution and found that we needed to clean the recycleable toner cartridge pipe and unit. We did that and the error code is gone but now it is only giving us blank copies. Do we need to reset the toner or something? Can you help me with this?
4 Suggested Answers
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
007tech
  • 95 Answers
SOURCE: I have 2 problems with my toshiba 550. service code CD3 and SPC
The CD3 error is related to the recycled toner unit. the recycled toner is backed up/clogged.
Toshiba made a parts change to the design of the recycle toner unit by replacing a bushing with a roller bearing and a seal. depending on how old your copier is it may or may not have this modification. The copier firmware/software also needs to be updated to the most current version and along with that there are a few internal settings that need to be adjusted.
If you are unable to do any of the above then try this - (it will get rid of the problem short term) clean/vacuum out the toner recycle unit.
If you open the front cover of the copier you will a white plastic pipe sitting at about a 45 degree angle (below the toner cartridge) - this is the pipe that leads to the recycle unit on the right. The whole unit needs to be removed and taken apart and cleaned, inside and out, including the pipe.
The SPC code is related to this issue and should also go away.
Hope this helps.
Posted on Apr 12, 2009
SOURCE: i need a master reset code for studio 550 toshiba PLEASE PLEASE P
error code c37
Posted on Sep 18, 2009
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
Toshiba e-studio 5520c cd81 keeps coming .even after cleaning the toner disposal bottle
This error code is not for the waste toner box. The problem is the transfer waste motor (right side duplex door of machine). Probably clogged auger stalling motor which needs to be vacummed out.
Aug 03, 2014 | Toshiba e-studio 5520c Digital Copier
ERROR CODE CF60 (photocopy toshiba E Studio 232).
this is a fault relating to the toner recycling system which is behind the black cover on the process unit-error code suggests that it has locked.
Feb 11, 2010 | Toshiba Office Equipment & Supplies
Hope this helps.
Mar 31, 2009 | Toshiba E-STUDIO 550 Copier
Error code CF60
Try check the cleaner unit of process unit whether it is full of toner that resulting the recycle toner transport area is locked thus CF60 sign on.
Mar 12, 2009 | Toshiba e-Studio 350 Copier
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Http://www.fixya.com/PostQuestion.aspx?prdid=148156#
cleaning out the toner recycle auger really good helps. the bushings get caked with toner and the auger won't spin well.
Jun 05, 2008 | Toshiba E-STUDIO 650 Copier
Hihttp://www.fixya.com/PostQuestion.aspx?prdid=148156#
CD3 is an abnormal recycle toner transport motor. it needs replacing most likely. Ive tried oiling them but end up replacing
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
103 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
