Question about LG WM1814CW Front Load Washer
Error reading CL. How can I fix this? - LG WM1814CW Front Load Washer
    Genius:
  • 1,168 Answers
I do not see a CL in the error guide for that machineerror reading CL. How can I fix this? - 21-2dea2d5f79.jpg
Posted on Feb 17, 2012
Error code cl
LG Washer Error Code Cl Fix. CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it
May 02, 2017 | Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
I purchased new ink cartridges PG-30 and CL-31 I get error 5
Make sure you take the tape off of the electrical contacts before installing, and if they are refilled cartridges they have not been reset properly. If they are genuine Canon, you can return defective ones for 30 days.
Nov 27, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Cd player keeps rejecting cd & show an peo-e error on 97 acura cl
PEO normally means Player Error Optical which means that for some reason the cd player is not reading the cd correctly.  This can happen if the disk is dirty or has a lot of scratches.  If the disk is clean and in good condition more than likely the cd player will need to be replaced.
Nov 11, 2008 | 1997 Acura CL
CL Error Dacor Dishwashwer
I had this problem and it was driving me crazy! I finally figured out what it was, in my case. I thought that the door switch would be the problem, so I took the door cover off and jumpered out the switch. No luck. While I had it apart, I noticed that each time I bumped the main control board, I heard a short, and heard a relay close. I found that the main control board wasn't snapped all the way into its mount on the left side. Apparently, there is a contact on the back side of the board that only makes when the board is fully seated. Snapping the board firmly into place has fixed my problem.
Mar 30, 2008 | Dacor Dishwashers
Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Mar 14, 2008 | Dishwashers
LG WM1814CW Front Load Washer Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
