Question about OKI C Office Equipment & Supplies
Oki c5600 printer paper jam 382
Why does it jam all the time. Just replaced a new fuser. black & white prints fine but color keeps jamming. Please help...
mattozan
  • 555 Answers
SOURCE: xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Posted on Mar 06, 2008
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
MalKontent68
  • 748 Answers
SOURCE: While printing with OKI C5600 very often error
Try cleaning all the paper feed rollers you can access, both from the bottom (paper tray pulled out) and from the front, behind the front door. It might be that the sheet is not fed properly and doesn't reach some sensor in expected time, thus the errors.
Also clean the separator - it's the small area on the paper tray where the feed roller touches; it needs some friction to hold the sheet(s) beneath the one being fed.
To clean use isopropyl alcohol or some kind of residue-free and oil-free cleaner on a piece of cloth or paper towel that does not leave lint.
Posted on Oct 24, 2009
lserni
  • 466 Answers
SOURCE: replaced the belt and fuser on a oki c5200, now
This will happen if the belt isn't properly settled, so that the sheet of paper enters at a slight angle and jams. The roller loader will then fold it into an accordion shape.
While I don't understand how the printer let you print (the sensor should have raised an alarm), you could try extracting the belt unit and re-settling it. Verify the blue retainers have been fully rotated (one eighth turn clockwise) and the handle is completely down.
Posted on Nov 06, 2009
SOURCE: Error code 382 paper jam on a ilumina digital
error 382 but dot paper jamp
Posted on Feb 10, 2010
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
After clearing a paper jam when you print the right side of the printed paper is not as dark as the rest of the page. I have replaced the fuser to no avail is there an adjustment that needs to be made?
Hi there! Wich color is not dark as the rest?Only when you print in black and white or even in the color printing? If the black or any of the colors are not dark as the rest of the page you must clean the led scanners(Wehn you open the top cover you will see long black boxes on the top cover,those are the led scanners) if they are clean then your transfer belt is damaged and can`t transfer the image from the drums to the paper.You can check the belt by starting a printing and open the top cover while the paper is moving under the toner cartridges and look at the page!Please replay what you have seen so i can help you futher!Thaky for usin Fixya.
Nov 29, 2010 | OKI C5200n Laser Printer
382:Paper Jam Right after you power get above
You have something stuck in the paper path. Check the paper path for torn paper.
Oct 25, 2010 | OKI C5400 Laser Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
I have a total of 10 HP Color LaserJet 4650 printers, and 7 of them have the following problem: they jam at the fuser whenever a full-color picture, photo, or slide is sent to print (especially ones with...
This jamming has to do with third-party toner cartridges being used. I had this problem using Xerox toner cartridges and found that I would have no jamming if I used at least 2 hp-brand toner cartridges and the rest Xerox. I then used a different brand of 3rd party toner cartridges that would not jam as long as just the black cartridge was a genuine HP black toner cartridge. This issue has been confirmed even by the manufacturers of the generic toner cartridges. Hope that helps!
Oct 15, 2009 | HP LaserJet 4650 Color Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Paper jam near fuser - OKI C5100n
okay, I have this problem I think. It is jamming on the OUTPUT side of the fuser, and I have replaced the fuser with a new one.
I learned tonight, through trying various things, that it will not jam with the printer lid open. (you can make it "print" with the lid open if you push the lid switch in so that the printer thinks it is closed. That made me wonder if it had anything to do with the led strips (black bars attached to the lid) so just for fun I unplugged the C led strip so that it wouldn't produce any light onto the drum. With the lid closed and the C disconnected, the printer will not jam. (but you get no blue on the page of course!) when I re-connect the C led strip, it jams on the output side of the fuser every time. It is very consistent.
I don't understand how putting blue toner on a paper can make it curl so much that it jams up in the fuser, but it does.
I'm sure there is something else gong on here that I don't fully understand- hopefully someone who knows more than I do can use this info to help us all out a little.
I'm going to go and fiddle with the drums now. I don't have an extra one right now, but I'll see if I can narrow it down further.
Sep 11, 2008 | OKI C5100n Laser Printer
Oki C9300
What is the status of your fuser unit and on what paper settings are printing on? When last have you cleaned tour machine?
May 23, 2008 | OKI C9300 Led Printer
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
125 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
