Question about Blaupunkt Los Angeles MP72 CD Player
Blaupunkt Woodstock DAB 52
Hi all,
I've got this DAB Rcv, fantastic sound, but died on me. At first it came on/off intermittently btw each drive, then suddenly it jus refuse to turn on totally. Chked the fuse, chked the connections all seem well. Plugged in my replacement set to the car and all worked fine, so its confirm that the fault's with the set and not the wiring. Has anyone opened up the unit before to troubleshoot before? Where or which part of the internal circuitry should we be attacking first?
Thks
Jeff(SGP_
3 Suggested Answers
  • 40 Answers
SOURCE: Blaupunkt MP74 no sound
MGBGT- This is a fairly common problem,you ford has a built in amplifier,there is a wire that needs to be hooked up.If you used an after market adaptor,this wire should be marked and needs to be hooked to the remote turn on lead of the deck.Let me know if you need help. cooltek Mar,4/08
Posted on Mar 04, 2008
LVT7857
  • 116 Answers
SOURCE: cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Posted on Feb 04, 2009
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
My woodstock dab 54 reads kcard not ok after i changed the battery and wont let me keycode number
Hey I could do with help on this as I have lost the kcard (Ihave the code)
Feb 18, 2012 | Audio Players & Recorders
Intermittent bleeping on tuned - in -stations
You have the traffic updates on - I'm not sure the traffic function has ever really worked on the 52 but turn it off and you should lose the annoying beep. As an interesting but annoying aside, you won't find this info on the Blaupunkt FAQ page searching under 'beep' because they describe the noise as a 'peep'... go figure!
http://www.blaupunkt.de/index.php?id=882&no_cache=1&L=1
May 11, 2011 | Blaupunkt Woodstock DAB 52 CD Player
Hi, I have a Blaupunkt Woodstock DAB 54, where I don't have the Master Key Card. I can see that I can use a normal SD card, and enter the 4 digit master key again. But I dont have it. I can see that we...
Hi , try 7589 , not sure if it will work but its a maybe , i also have a dab54 and i got the key wrong 3 times , now its been stuck saying wait 1 hour for the past 8 hours , i think imma introduce my hammer to it , hope the code helps :)
Apr 30, 2011 | Car Audio & Video
What is the scanner frequencie for Woodstock City Police. Woodstock Ontario Canada
Here is the info from Radioreference.com.
http://www.radioreference.com/apps/db/?ctid=4312
139.77000 Woodstock City Police (Ch7)
142.42500 Woodstock City Police (?)
142.47000 Woodstock City Police (?)
142.68000 Woodstock City Police (Ch 1)
142.68000 Woodstock City Police (Ch 2)
142.86000 Woodstock City Police (ch 5)
142.92000 Woodstock City Police (Ch 6)
413.23750 Woodstock City Police (UHF)
158.38500 Woodstock City Fire
Hope this helps - J
For all of you scanner needs try ScannerMaster
Nov 18, 2009 | Radio Shack Pro-95 Handheld Scanner
I'm trying to replace rear speakers in my 99 ford expedition and i'm trying to find out the size and how to install
Ford usually fitted elliptical speakers in their models in the 1990's so it's possible that yours are 6"x9" or something similar.
You can get replacements from Ford, (which are usually very expensive!) or buy some better ones on the Internet, such as Ebay or Amazon.
I bought a pair of German Blaupunkt 6x9's for my car from some site I found on Ebay and the price was around half of that to buy the *same* speakers from Ford Spare parts Dep't!!!
The sound is fantastic!
PS: You should be able to access the rear speakers below the rear parcel shelf at each side of your Expedition. They are held in place by 4 screws, which usually have a Posidriv (+) type screwdriver head.
When refitting, make sure!!! that you fix the +ve spade terminal to the +ve marked on your new speaker & the -ve terminal to the -ve. Do this on both speakers to make sure that they are both in-phase (so both bass drive units are pushing air forwards together). If you don't keep them in phase, the speakers will produce much less bass - which is clearly noticable!
Hope this helps
Nov 17, 2009 | 1999 Ford Expedition
Blaupunkt woodstock 54 has a mind of its own...
Hi
Ive got the same unit & they can be a bit unpredictable.Theres a way around it as the unit facilitates a 'NORMSET' feature which allows the user to reset the unit to basic settings as when it was first taken out of the box.
Also the sd card you use can only be 1gb or less & has to be formatted in 16kb through windows XP or Vista.
If you want to know more get back to me & I will talk you through it,it sounds like the units been corrupted by a sd card that wasn't formatted correctly as this happened to mine but now is sorted.
The WOODSTOCK Range aren't made anymore,the latest version is the NASHVILLE,and I was advised that my unit may have had to go back to Germany for reprogramming as no-one really knows about them in the UK.
However I sought advice and problem was rectified.
Mar 21, 2008 | Audio Players & Recorders
Blaupunkt Los Angeles MP72 CD Player Logo
76 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
