Question about Sanyo DS27800 27" TV
Flickering multi-colored line in the middle of the screen.
I purchased a Sanyo 27 inch TV - Model # DS27800 in 2001.
My problem with it now is… the screen has horizontal lines that flicker, then the picture goes black on the top & bottom with a bright multi colored line in the middle that throws of horizontal lines that flicker (it seems like the TV is trying to fill the screen). The sound is fine and everything else seems to be fine. Is there a fix/solution for this problem?
  • poasvcllc Nov 12, 2008
    The very same problems with our Sanyo DS27800....happened all at once. The flickering color line is about the thickness of a pencil..great sound...all channels are the same.
  • 89 Answers
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Posted on Mar 12, 2009
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My model number is ds27820 and i just get a thin line
This is a common problem with the vertical output IC and vertical section. (if the line is from left to right in the center of the screen)
Most shops will repair ths problem for under $100
Sep 28, 2009 | Sanyo DS27510 27" TV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Picture tube
no you have no vertical bad chip ic
Oct 21, 2008 | Sanyo DS27820 27" TV
Sanyo TV model DS25710 or DS25730
Set has a bad vertical sweep IC. Also This Sanyo has a tendancy , when the IC blows out , to take the fusable resistor in the sweeo supply that feeds the vertical IC. This set should only be serviced by a trained technician because of ther high Voltage that lingers within. This repair should run you antwhere from 85.00 to 150 bucks. Good Luck
Jul 31, 2006 | Sanyo DS24205 24" TV
Sanyo DS27800 27" TV Logo
365 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
