Question about Canon PIXMA iP1800 InkJet Printer
I need to change my printer ink - Canon PIXMA iP1800 InkJet Printer
  • Canon Master
  • 672 Answers
Where can I get a Parts List for a Canon MX850 MF Unit
Ink Absorber Full
This may clear the ink absorber problem.
There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Apr 23, 2013 | Canon PIXMA MX850 Multifunction Printer
Ink absorber full
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
Jan 19, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Change ink cartridge
For many you need to turn the printer on, lift the lid that covers the ink tanks, and on the on printer display scroll menu to change ink or something to that effect. Alternatively, if you have the Epson printer utilities on your system, go to Control Panel, hit the printer icon, properties.......
Apr 02, 2010 | Epson Stylus CX6600 All-In-One InkJet...
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
Ink Absorber full,needs changing.How do I Change
You need to disassembling the hole printer to find and replace the ink absorber.It's on the bottom from right side under the pump station.
Also you need to reset the ink counter:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Changing ink carthrige
hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
1.maybe your ink is not compatible or not detected..
2.maybe your ink carrier is most likely defective.
hope this would help you...
Oct 27, 2008 | HP DeskJet 820cxi InkJet Printer
Ink
with injection purchase the ink from market and use injection to change the ink
Sep 29, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Canon PIXMA iP1800 InkJet Printer Logo
69 people viewed this question
old marine
old marine
