Question about Kelvinator Refrigerators
Kelvinator fridge icing up on back wall
Hi there my Kelvinator upright fridge freezer has a problem... in the upper (fridge) compartment ice keeps building up on the back wall... dows anyone know how to fix this problem?
  • 139 Answers
SOURCE: freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
Posted on Dec 04, 2007
  • 1073 Answers
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
SOURCE: Have a 17 year old
You problem lies in a blocked drain or a broken drain connection to the metal drip tray at the bottom of the freezer heat exchanger. You could try blowing the drain out from beneath the fridge, which is difficult as it is very hard to access. Alternatively you will need to remove the tray. This means you have to remove the contents of the freezer, remove the lower long white metal cover and blow out the drain. Then test the drain with a cup of water. If it leaks into the bottom of the freezer compartment you will have to remove the drain and epoxy the joint together again.
Not a job for the faint hearted!
JB
Posted on May 05, 2008
  • 31 Answers
SOURCE: Kelvinator 360 Fridge Wheel Adjustment
If you have the manual.... check under leveling your appliance.
I don't know Kelvinator but most have screws/bolts that can be turned behind the air vent cover at the bottom front of the fridge that will raise or lower the fridge. Sorry I couldn't be of more help.
Posted on Jun 30, 2008
  • 31 Answers
SOURCE: Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
I have a kelvernator fridge/ freezer and woke up this morning to find the freezer part still working but not the fridge part, why do u think this is ?
The most common cause of that is a malfunction of the automatic defrost system. Do you see a bunch of frost on back wall of freezer? if yes it's not defrosting or perhaps the fan in the freezer that circulates air into fresh food compartment has failed,no frost build up if it's the fan, do you hear the fan?
Gene
Jul 30, 2011 | Kelvinator Refrigerators
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 05, 2011 | Frigidaire Freezers
Hello, I have a kelvinator fridge. my fridge is not working properly. actually it's not as cold as it should be and the main problem is that the freezer is not making ice and there is no ice formation on...
You can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kelvinator Freezers
How do you defrost the kelvinator cyclic 300 fridge?
hi,
a manual defrost? unplug and get a 9by11 cake pan and a bunch of towels and a hairdryer. put the hairdryer on LOW only and get it positioned in the freezer (door) compartment so its pointing towards the back. cake pan in the bottom towels below. and on the floor. leave the door open about 3 or 4 inches but NOT shut so you have some air circulation. and check it frequently. make sure the hair dryer isnt pointed at the plastics at all. takes a day. pull it from the wall, remove the rear access cover behind the fridge and blow it out with a vac or air compressor too. theres an access panel inside the freezer and if your handy, your ice blockage causing that problem lives behind there in the freezer. use caution if your going to attempt taking that plate off inside. use nothing sharp.
jm
Dec 08, 2010 | Kelvinator Freezers
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
62 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
