Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Tv trouble tv color not right is there blown fuses?
  • 905 Answers
This is not a blown fuse , you will need to get a convergence done by calling your local repair shop to have it repaired. if you havea warranty use it otherwise it will cost about $400 for the tech to come out to repair it
Posted on Oct 26, 2008
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
Power failure
if their is no power indicator at all that was mean the power supply failure. look for blown fuse, if the fuse is blown with darkened color you need to check first other component that get shorted pin before you replaced the fuse like zener diode and fet transistor. if you don't have an idea on how it will be trouble shot just send it to the service center near you.
Aug 03, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My TV Wouldn't On
if no any power light indicator at the front of your tv that was mean the unit is dead set or no voltage that is circulating in the main board and other boards.if you can remove the rear cover of your tv, the first place to check will be the power supply board if the primary fuse was blown. if the fuse is blown with darkened color that was mean has shorted component either in the main board or in the power supply unit. if the fuse blown with clear color just replace with the same rating.
Aug 02, 2012 | Televison & Video
TV does not come on at all.......would there be some replaceable fuse?
Certainly there will be a replacable glass cartridge type fuse. It will be there, not only for Sanyo, but for all TVs. The fuse used is for protection. That is, if anything wrong happens to the power supply or its internal circuits, fuse will blow up, and prevent further damage to other components. Therefore, you must understand that if fuse in your TV has blown up, certainley there will be some reson for that. Without find that reason, and rectify it, never put a fuse there, it it has blown. It will cause more trouble to your device. Check it well. Find out the reason for the blown out fuse. Rectify it first, and then put a new fuse there. OK.
Mar 12, 2011 | Panasonic CT-32SL13 32" TV
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
Polaroid pla-4248 red color only in right lower side of screen, found 14 amp fuse blown on panel on right side,did not solve the problem
Looks like Y-Sustain board fails .First of all there is no 14 A.fuse used on this tv. and replase with the same Amperace.If you use bigger Amp, it could damage the power board
Jul 31, 2009 | Philips 50PF9630A 50 in. Plasma Television
Tv runs on 110 but not 12volt
There is a fuse on the DC power line for AC/DC sets and you can start by making sure it isn't blown. The fuse may be in the cigarette lighter plug itself, or inside the TV. If you find the fuse blown, replace it with one of the same value and try it again. The fuses sometimes do go for no good reason. If there is some internal trouble with the TV, the fuse will go again and you'll know for sure.
Nov 30, 2008 | Supersonic FC2245 13 Color TV/DVD Combo...
Panasonic TH-42PX600U plasma TV. No power at all. Where is the fuse (if any)?
I'm having the exact same problem. My Panasonic 42 inch TH-42PX60U just turned off while I was watching TV. I removed the fuses (both were blown) and replaced them and am now getting the red light that blinks ten times.
What should I do now???
Nov 10, 2008 | Televison & Video
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
