Question about Datamax I-4208 Thermal Label Printer
Datamax I-4208 has different position than i-4308 or prodigy max
We use Bartender for our labels. Labels set up with default settings in Bartender 9.41 are offset down on the i-4208 ~ 1/8". On an i-4308 or datamax prodigy, the labels print as expected. We have 2 i-4208s. Same effect on both. Reset one to factory settings, still the same result. There is about 1/8" of missing margin at the top. Changing the label definition larger or smaller results in more unusable area on the bottom. Label size is determined by the gap sensor, as recommened by Seagull. Setting manual label size has the same result of missing space. Anyone run into this before? Any ideas?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Posted on Apr 29, 2014
Riztech
  • 731 Answers
SOURCE: Datamax M-4208 shows ready but does not print
I belive that, PC can detect the Printer and the only problem, the drivers are unabled to route the print queue and that creates a problem.
If your OS is XP/Vista/2000, try the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall. ((IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Datamax M 4200)).
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Posted on Feb 09, 2008
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
  • 54 Answers
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Posted on Feb 25, 2009
bartech9
  • 155 Answers
SOURCE: Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Posted on Jun 10, 2009
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
Can I print labels using DPL to a networked Datamax I-4208 using C#.NET?
greg babcok: You can do printing via tcp/ip packets or using Windows spooler. I have some example in vb.net
Roberto Martinez
Apr 27, 2011 | Datamax I-4208 Thermal Label Printer
Label print too light
This could be caused by the darkness setting coming from the label software / printer driver. It's set too low and that setting will usually override the darkness setting in the printer. That's why test labels are fine.
Hope that helps.
Apr 08, 2010 | Datamax M-Class 4208 Thermal Label Printer
Datamax i -4208 printer
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Nov 24, 2009 | Datamax I-4208 Thermal Label Printer
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Label printed too long
¿Que software de diseño estas utilizando (label matrix, codesoft, bartender) ? Estos programas tienen sus propios drivers, pero cuando utilizas otro driver puede haber conflictos con los tamaños de las etiquetas. Verifica que las dimensiones de la etiqueta en el driver y en el programa sean los mismos y que los margenes sean los correctos. What design software are using (label matrix, Codesoft, bartender)? These programs have their own drivers, but when you use another driver may have conflicts with the size of the labels. Verify that the dimensions of the label on the driver and the program are the same and that the margins are correct.
Jan 19, 2009 | Datamax I-4208 Thermal Label Printer
Datamax problem
Dec 18, 2007 | Datamax M-4208 Thermal Label Printer
4208 Datamax M Class printer Problems
Check inside the green guide (sensor) for pieces of label. That will block the sensor. If the sensor is reporting a thickness which is double (250) what you expect, then that is definitely the issue.
Jun 27, 2007 | Datamax M-4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
168 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
