Question about Alpine CDA-9833 CD Player
CDA - 9833 AI-Net issue
I was recently installing a XM system on to the CDA-9833, when I stupidly cut off the pig tail that was not being used between the AI port and the XM controller. I did not understand, at the time, that I could daisy chain on other components like a CD changer or what ever to that empty end of the cable. I was able to get the XM preview channel before I made the cut. I bought a new cable and XM receiver and controller and that still did not work. The CDA-9833 still plays CDs, I still get radio but no AI-Net functions. Thanks for the help.
  • 752 Answers
If the radio was still plugged in when you cut it (such a BAAAADDD idea....) it likely shorted the data pins to the power pins which fried the AI net processor. There is no fix for that. It's toast.
Posted on Dec 08, 2007
Ai-NET cable is cut, wire splice male aux cord
On the ai net cable identify and separate strand with green, blue and unshielded common/ground. G and B will be your positive which you will then solder to red and white leads from rca or headphone cable with unshielded from that cable twisted together and soldered together with the unshielded wire from ai net cable. Tape off or heat shrink the rest of wires from ai net cable.
Sep 29, 2013 | Alpine CDA-7863 CD Player
Hey,I have an 03 chevy s10,I recently tried putting a pig tail on it (straight wired) and had no luck,gave up and crimped all the wire back together,and today a guy at work noticed I had no taillights,but...
I would check your tail light fuse first then test the brown wire in the tail light harness where you origionally cut into it. With the lights on there should be around 12v on it. if not you may have pulled the wire too hard and broke it upstream. Test to see if there is 12v at the fuse ad if there is, your trouble should be in the wire between the fuse and the spot where you cut into it.
Mar 25, 2013 | Cars & Trucks
What is Ai net
ai net is simply alpine's upper level line of decks. they have their regular line and ai net line. just like kenwood has their normal line and their upper level excelon line. ai net uses different cables to connect with changers and aux items than the regular line.
Apr 18, 2010 | Alpine CDA-9883 CD Player
Haveing trouble hearing sound when I have my IPod connected
You need a AI Net cable or Speed Cable... It plugs into the back of the radio (looks like a circle with holes), and the other end can have a "Y" plug (headphone jack and iPod flat jack). The headphone jack for sound, the flat jack to charge he iPod while listening. I just bought mine on Crutchfield.com for $29.99. With the discount code: 3A156 you can get standard shipping free. The item # is: 127ICALPA and it's named "PAC iPod Adapter for Alpine".
Mar 14, 2009 | Alpine CDA-9833 CD Player
What is the AUX good for
I use the Aux to plugin my Ipod, amke sure you have it set on. Then it acts as the plugin. it was originally there for XM radio or a tv.
Sep 24, 2008 | Alpine CDA-9805 CD Player
What lead do i need to get to play my ipod through it
you will need an ai-net cable. your local car audio dealer will definitely know.
Jun 09, 2008 | Alpine CDA-9811 CD Player
Volume won"t pass 20 cut's off dack
the speakers either cannot handle the poew and shut off to protect the radio- or the wiring for the speakers are not insulated well or your groung is not good
Mar 26, 2008 | Alpine CDA-9833 CD Player
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Alpine CDA-9833 CD Player Logo
210 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
